Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washing machine gtlf490e
The dang thing wont spin to ring out clothes. it will wash, then drain but all it does in spin mode is hummmmmm... i have replaced both main boards and checked for if something was clogged i ddint see anything what else could it be or am i not looking in the right spot? it does fine on the test mode .. it spins fast on the test mode . so i cant figure out why it wont do it in the cycle mode?? someone help me .. wont buy frigidaire again.. I have replaced the control board twice on my machine. Now it has broken again. It reads an error code that the computer thinks the door is open during spin, so it does not spin at the end of the cycle resulting in very wet cloths. I have tested the resistance of the PTC switch, and it is fine. Can you help?
    Genius:
  • 1,028 Answers
Just change the door switch been there done that have the t shirt
Posted on Sep 07, 2008
Will not wash
motherboard of the unit may be defective
Dec 25, 2013 | Frigidaire FAFW3574KA Front Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
My frigidaire washer model # fws545rfs0 wont drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 21, 2011 | Frigidaire Washing Machines
Not spinning clothes
heatman101
Feb 03, 2011 | Frigidaire ATF6000ES Front Load Washer
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My washing machine will not drain th water out,at the final spin the water will not ring out
heatman101
Oct 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will not complete spin cycle clothes are still wet
Sep 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLT F 2940 ES Front Load washer. Spin is slow. Clothes wet
heatman101
Sep 03, 2010 | Frigidaire Affinity ATF7000ES Front Load...
First of all check the motor.most probably its got weak so its spinning when empty but not spinning when there are clothes in the machine. It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jun 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
ill save us some time that washer is one of the best out there i have one my self pop me an email at b4829@yahoo.com and check my4 boxes say in e mail front loader wont spin ill send ya something
May 21, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
252 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
