Question about Dell Inspiron 6400 Notebook
Battery plug-in black out
I am getting the opposite to most people. My laptop will run fine without the plug-in. It will charge with the plug in. But when I try and use the plug-in and run my laptop (for better light and longer use) it turns my screen black. If I disconnect the plug-in battery and close the lid on the laptop, my screen will come back and I am good to go. Can someone help me.
tks
sandy
  • 41 Answers
Sounds like a ground issue between the AC adapter the motherboard. Have you tried another or spare AC adapter?
Posted on Sep 17, 2008
Laptop without battery turns on at one plug socket but not another plug socket, i'm confused???
Sounds like there must be enough of a difference in the quality of the power at the friend's house that makes a difference to the laptop.
Unfortunately the meters are very expensive:
Extech 382090 3 Phase Power Analyzer Data Logger
Jan 02, 2015 | Samsung Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
My acer Aspire 4741 laptop does not charge its battery. that is why every time i use it, it is plugged in. what could be the problem?
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
In some situations the battery can become loose. Removing it and then put it back into the laptop.
To remove the battery slide this switch to the opposite side and hold it in that position until the battery is removed. When doing this with some laptops the battery will pop out and allow you to grab onto it. Others will release the latch and require you to grab onto the battery usually with the tips of your fingers and pull it out.
In most cases this will help, but if the problem persist you may have to get a new battery for your laptop.
Good luck
Aug 27, 2011 | Computers & Internet
Hi, I really need some help. I want to know whats wrong before taking my hp pavllion dv600 to service centre. Problem is that the charger doesn?t charge the battery at all. Charger is fine with other...
If the power supply does not run the laptop without the battery, then the problem is the jack in the laptop, over time the plug breaks free of the motherboard causing intermittent operation or no power. If the power supply runs the laptop without the battery, it is the charging circuits on the motherboard that is the issue.
Jan 04, 2011 | Computers & Internet
The power light is on but my satellite A75-229 won't turn on. It was on last night running fine. The battery ran out because I forgot to turn it off so I plugged it in and pushed the power on button and...
Try letting the computer sit without the battery for a few minutes, and also without external power. Then try plugging in your external power WITHOUT the battery and try to start it up. If it does, add the battery while it is running. Then try it with the battery only.
Nov 30, 2010 | Toshiba Satellite A75-S229 Notebook
Battery dead in my HP laptop will not start with power cord
take out the battery and try to start the computer with it plugged in using the power lead. If this owkrs without the battery being in then the power lead is fine. If this doesnt work it could possibly be the power lead or the power supply inside the laptop. Does the power lead converter (the black box half way down the lead) get warm when plugged in for a while, if so the power supply is probably the fault
Jan 20, 2010 | Computers & Internet
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Dell Inspiron 6400 Notebook Logo
48 people viewed this question
Alun Cox
