Question about Intel Motherboard
915p/g combo D-bracket 2 LEDs
I would like to know what is the meening of the LEDs (all the combinations) for identifing the problem at my computer.
  • elmalemus Sep 07, 2008
    i know what is "LED" i have ment what is the problem that each LED indicate about.
  • 53 Answers
Meaning is light-emitting diode.
Posted on Sep 07, 2008
My indesit wixl143s, fills with water normally but immediately it drains. washing movements do not start. When manually set to rinse and spin cycles it works.
I would like to know is there any fault code?
Identification of the error code using the 4 LEDs. One or more different combinations of LEDs indicates the failure.
25889772-23mqg50qavgoaobxweiobkxp-5-0.jpg Dado
Oct 02, 2015 | Indesit Washing Machines
How do i change a turn signal relay on a 2000 Chrysler Concorde
The Combination Flasher, also referred to as the combo-flasher, is mounted to the in-line bracket which is located to the right of the Junction Block. The flasher can be removed by pulling in a rearward direction. The left under panel silencer duct must be removed to access the flasher. The combo-flasher is black in color for ease of identification.
The Turn Signal and Hazard Warning Flasher is combined into one unit called a Combination Flasher (Combo-Flasher). The combo-flasher controls the flashing of the hazard warning system and the turn signal system. An inoperative bulb or incomplete turn signal circuit will result in an increase in flasher speed.
Ref: http://www.10w40.com/questions/auto-repair-questions/where-is-the-flasher-relay-on-a-2000-chrysler-concorde
Good Luck
Mar 03, 2015 | 2000 Chrysler Concorde
Where is the relay for the turn signals
some are at the fuse box inside the car some are in the engine compartment fuse box check your owners manual
Feb 16, 2011 | 2002 Dodge Intrepid
Have purchased a Kryptonite RCL 111 and upon wanting to use it the 0005 combination does not open the lock and hence I am unable to use the product. Can you assist? Thanks You Roland
brand new locks come preset with a ' 0000 ' code and then you can change it to whatever you want -- so I would try and set the wheels to all zeros ( 0000 ) and see if it will open then. if you bought this lock new and set it to a combo and the lock does not know the code then there is a chance that one of the combo wheels has broken ( this happens all the time ) --- take the lock back to the store that you bought it from and tell them that it is broken and they will replace it with a new one.
if you did set the combo but you forgot what the combo was or it was set wrong - then you can try and progress the combo by starting with 0000 ' try the lock ' then 0001,then 0002,0003,0004 etc.. all the way thru all the numbers until the lock opens,,, this does take some time and at the lock shop that I work at, we see this all the time and we try 'em in our spare time --- going from 0000 to 9999 usually takes about 1 1/2 hours to 2 hours to spin thru all the digits. ( this is really the only way to figure out the combo ).
c...
Jan 23, 2011 | Kryptonite Rcl 3 Combination Cable Bicycle...
Where is the turn signal flasher unit located on a 2001 Chrysler Concord
here is the location of the flasher The Turn Signal and Hazard Warning Flasher is combined into one unit called a Combination Flasher (Combo-Flasher) The combo-flasher controls the flashing of the hazard warning system and the turn signal system. An inoperative bulb or incomplete turn signal circuit will result in an increase in flasher speed.
The combo-flasher is mounted to the in-line bracket which is located to the right of the Junction Block. The flasher can be removed by pulling in an rearward direction. The left under panel silencer duct must be removed to access the flasher. The combo-flasher is black in color for ease of identification
Nov 26, 2009 | 2001 Chrysler Concorde
Where is the turn signal flasher unit found on a 2001 Chrysler Concord
COMBINATION FLASHER LOCATION The Turn Signal and Hazard Warning Flasher is combined into one unit called a Combination Flasher (Combo-Flasher) The combo-flasher controls the flashing of the hazard warning system and the turn signal system. An inoperative bulb or incomplete turn signal circuit will result in an increase in flasher speed.
My videocard has LEDs but the manual dosent say what they meen
That card is so new I can't find any information either. If it ain't broke...
Nov 05, 2009 | Computers & Internet
Dual core support?
If its based on an intel 915 family chipset, it would not support any of the newer core processors.
Mar 17, 2008 | MSI 915P Combo-FR Motherboard
Intel Motherboard Logo
226 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
