'input not supported'
I bought an acer 1916wab 19" widescreen, not sure this question belongs here, but all I get after windows starts is a message saying 'input not supported'. I also noticed a sticker on the base of the monitor saying 'for Windows vista'. I am running Windows XP professional version 2002. Will this monitor work with my system (446MHz, 320 ram)? How do I get it to work? I can't play counter-strike 1.6 when i click at the game Saay INPUT NOT SUPPROTED
  • 1 more comment
  • rossfamily76 Oct 13, 2008
    I'm getting an "input not supported" box on my Acer monitor and I'm not able to do anything. I have to shut the computer down incorrectly because there's nothing to click on. How do I get around this? It's an older computer (HP) with windows 97--not our main computer. Hope you can give me some advice.
    Thanks!! kr
  • luv_the_spor Nov 28, 2008
    I have the same problem and again, when I boot in safe mode I still get the input not supported screen. Sombody help?!?
  • Anonymous Feb 02, 2009
    ths
Restart the computer
While the computer is loading, press "F8" key on the keyboard right before the computer reads the hard drive or press the "F8" key multiple times in 1 second interval until the "Windows Advanced Options Menu" appears on the screen
Under "Windows Advanced Options Menu", using the arrow key on the keyboard, select "Enable VGA Mode" then press Enter.
Select "Windows 2000 or Windows XP" for your operating system.
Wait while the computer is loading and once the computer finishes loading,
Right Click anywhere on the blank area on the desktop
then click "Properties"
Click on "Settings"
and adjust the screen resolution
Posted on Apr 01, 2011
Just had this problem and just fixed it. all you need to do is unplug it directly from the outlet then turn on it worked for us so hiopefully it will work for ya'll
Posted on Oct 27, 2008
I have this problem and screen is black no matter how I boot the computer. willnot worki in safe mode or regular. now what?
Posted on Nov 10, 2008
  • 661 Answers
You need to reset your graphics card settings as you may be using an invalid monitor mode.....
boot into safe mode, and reset your screen resolution to 640x480, reboot into normal mode and then you should then be able to select the correct mode for this monitor, if you are just having problems with a particular game, you just have selected an invalid monitor mode for that game, go into game options and select a different monitor mode/resolution, this should fix..
the monitor is vista compatible, not exclusivly for vista...so you shouldn't have a problem there
Posted on Sep 22, 2008
"Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Jul 13, 2009 | Acer AL1916W 19" LCD Monitor
yes it will but u need to adjust it to 1024x 768 60 hertz in settings menu ok
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
I have 3 acer al1603w widescreen monitor.. it was working ok before, then i let my brothers used them. afterwhich it is displaying "input not supported". WHOAAA!?!!? what do i do? its bugging me for 3 days...
Sounds like somebody messed with the monitor setup on the monitor controls. Check the manual to set it up correctly. If they changed the monitor's Frequency settings, the problems you are having will occur. Gotta set them back to 70Hz and check the other settings. If you need a manual, get back to me with the exact model number of the monitor.
Jun 11, 2009 | Acer AL1916W 19" LCD Monitor
How to change resulution when you get input not
Try starting Windows in Safe Mode. During boot, before windows starts loading, just keep tapping F8, until a menu appears in which you can select Safe Mode. In Safe Mode, set the resolution to a safe, low value in the control panel. Then reboot normally, and everything should work fine.
Jun 07, 2009 | Acer AL1916W 19" LCD Monitor
First install another monitor so Windows will load.
Then right click on "My Computer" and select "Properties", then click on the "Hardware" tab and click on "Device Manager" button. In the list and click on the "+" sign next to "Monitors" then right click on the monitor in question and select "Uninstall", then click "OK" and close all windows and "Shut Down" your PC. Install the monitor in question again and start your PC and wait 10 minutes or so and XP will set up the monitor like it's the first time you installed it.
I hope I understood your issue and Good Luck.
Apr 08, 2009 | Acer Aspire 3680 Laptop
Input not supported
In display properties under advanced, lower your refresh rate to 60 hertz. Then go up until it no longer supports it then back off a notch.
Feb 28, 2008 | Acer Aspire™ T180 PC Desktop
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
what you may need to do is find an accepted screen resolution, as your screen is 19" widescreen and your notebook will be set for a normal monitor display, so either try the auto button on the screen or look at the properties of your graphics card om the notebook to find supported screen resolutions for extended displays.
Aug 28, 2007 | Acer AL1916W 19" LCD Monitor
Input Not Supported?
Try changing the resolution in the game. If that doesn't work change the resolution in 'Control Panel' under 'Display'
Jun 28, 2007 | Acer AL1916W 19" LCD Monitor
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
4,233 people viewed this question
David Payne
David Payne
