Question about Dell 946 All-In-One InkJet Printer
Dell 946 printer
Hi
My Dell 946 is not consistant when it prints sometimes I get an entire page others times I do not sometimes print is to small to read. I also have enough ink the P.C. tells me at laest 30%.
Thank You!
  • Anonymous Mar 01, 2009
    My 946 dell printer will not allways print. Some times it will print right away and some times not untill the next day and some times never.
    Genius:
  • 1,124 Answers
You need to set the size of your page on the printer preferences.
If you need more help you can see the manual of your printer here: http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Posted on Sep 24, 2008
Why my Dell 946 printer wont print
Have you installed the printer driver? If you did and it won't print....uninstall it and reinstall the driver.
Jan 04, 2017 | Dell 946 All-In-One InkJet Printer
Prints every other page
In print setup make sure print pages isnt set to even or odd pages - choose all pages
Mar 15, 2011 | Dell 946 All-In-One InkJet Printer
My Dell 946 All in one printer prints all pages at an angle.. how do I fix this
go to your printing options... maybe, all the things you will print are set to a specific angle.
May 02, 2010 | Dell 946 All-In-One InkJet Printer
Not Printig
When you select print, you should see a preview before it prints. Then you can check your settings. Select, print entire page.
Apr 17, 2010 | Dell 946 All-In-One InkJet Printer
Dell 946 Printer
check on the series of the ink cartridge you got
946 all in one's has a lot of series for the cartridge
Sep 19, 2009 | Dell A940 All-In-One InkJet Printer
My dell 946 printer won't print
open the case take out catridges clean their heads with tissu shake them watch if some ink take on tissue paper catridge tends to dry when not used for long time
suyyam@gmail.com
Jul 22, 2009 | Dell 946 All-In-One InkJet Printer
Solution for "dell 946 aio reads error 1203 replacment cartridge wont read"
This is what I found on a Dell Community site.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Hope this helps
Ranjit
ranjit@supportminds.com
Jun 16, 2009 | Dell 946 All-In-One InkJet Printer
I have a Dell 946 printer that is a couple of years old. It has started printing crooked on the pages. I have done the alighnment and that did not fix the problem. Can you help?
probably no much you can do the correct the problem because The problems that users encounter while using a Dell printer
varies with the model. However the common problems all Dell printer models suffer from are their slow speed and faulty paper feed mechanism. Quality of prints varies from one model to another, but most of the models do not produce prints having very fine qualities. A Dell printer is particularly notorious for its poor and faulty feed mechanism. They tend to cripple the papers or take in large number of papers at a time and print parts of documents on each page. They keep on generating messages indicating lack of paper, no matter the paper is being supplied or not. Such a problem makes the printer absolutely useless
Nov 20, 2008 | Dell 946 All-In-One InkJet Printer
Dell 946 -carriage jam/stalled
the ink carriage is in far left position and jammed. it appears that the black cartridge far left was not seated correctly. how do i resolve this?
Nov 19, 2008 | Dell 946 All-In-One InkJet Printer
Dell 946 All-In-One InkJet Printer Logo
439 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
