This is a odd problem, all of a sudden BBC1 has seemingly untuned itself and i cant get it tuned in again. To look at the picture at present it has kind of green/red blotches visible in a kind of snowy effect on the screen. First of all i thought it must be the coax but no, ITV1, BBC2, C5 & C4 all have absolutely perfect pictures. I tried the auto retune on my TV and it went through all the channels and locked onto them... except BBC1 which it just skipped, so i tried a manual retune just on BBC1 and couldn't get any better picture than described above. It gets even stranger when BBC1 on my ITV Digital box looks perfect, as do all the rest of the channels, so that rules out both coax and the arial. TV is a Toshiba 3387DB
Have you recently plugged in a DVD player, VCR or ITVD box?
If so the output channel of one of these could be interfering with BBC1.
Andy
Was this helpful?
Yes
No
Solution #2
posted on Aug 07, 2005
Ross - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Nope none of those, the only thing i've done is go behind the TV to paint the wall, but then again i've checked that i didn't stand on any connections and reseated them. I cant understand how only BBC1 is affected, and only thru terrestrial and not ITVD (which comes thru the arial as well)
Was this helpful?
Yes
No
Solution #3
Peter1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Try a different preset for BBC1 - sounds like preset 1 is knacked
Was this helpful?
Yes
No
Solution #4
Chandler - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
i have something similar with my sanyo video. all 5 'normal' channels (well maybe channel 5 isn't exactly normal) tune in fine on the tv (although reception through the rooftop aerial isn't great - wish they would come and install cable in out area) and all tune in fine on the video except for channel 4, even though the picture received for channel 4 is a lot clearer than that for bbc1 and channel 5 for example... have tried fine tuning the video but with no success. it used to work fine but then just stopped earlier this year. if i video stuff on channel 4 now the picture comes across fine but the sound keeps on cutting in and out. most annoying... programs on other channels video fine. any ideas anyone?
when TV first switched on picture is narrow across middle of screen. after upto 10 min picture...
(More)
when TV first switched on picture is narrow across middle of screen. after upto 10 min picture widens to full screen. model toshiba 3387db. a
Toshiba 3377DB: My TV will not switch on, although when I push the on switch it appears to be off...
(More)
Toshiba 3377DB: My TV will not switch on, although when I push the on switch it appears to be off but it is making a hissing noise as if it is going to switch on. I have check the 2 internal fuses I can find on the PCB there are working.
tv keeps going on standby have to switch off for few secs then on then its fine for 1.2.3/8hours...
(More)
tv keeps going on standby have to switch off for few secs then on then its fine for 1.2.3/8hours then goes off
tv toshiba 2987db is stick on standby tv switches on ok then goes on standby then the green light...
(More)
tv toshiba 2987db is stick on standby tv switches on ok then goes on standby then the green light under the stanby light starts flashing have to get up switch it off till lights go out then its fine for few hours can u help
