Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell i have a proheat and the toothed belt keeps falling off i was told i neede a new thing called a cockle is this true if not what is the problem with the belt please.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tyyt
Posted on Sep 30, 2010
Replace belt on Bissell 7901 Proheat
On the underside of the unit, you will see a red cover about 1 inch square held on by a phillips screw on one end of the brush roller unit...remove it & you will see the toothed rubber agitator brush belt.
Sep 05, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
BISSELL PROHEAT, RENEWED THE TOOTHED BELT BUT IT KEEPS SLIPPING OFF.
heatman101
hj
Jul 23, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do I change the belt on the Bissell Proheat
heatman101
vm
Mar 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My Bissell Proheat 12 amps' brush keeps dragging on the carpet when I go to push it forwards. And it releases alot of water.
Mine is doing the exact same thing..Push it forward and it makes a awful noise. The Brush on the bottem is loose and it isnt spinning. SO i took and turned it over and there is a metal gear like part that runs the belt on the brush. I took it out and cleaned it...basically because it was just hanging in there..not Turning the belt..AND NOW I cant get it back in..I am totally disgusted as it hasnt been used very much at all. I cant get the gear metal piece back in to see if it works.IT Just falls out. and its a bear to get it in there..
Feb 07, 2010 | Bissell 8910 ProHeat Clear View Upright...
Bissell Proheat 25A3/64D9 series - cleaned one rug - now the wheels won't turn and it looks like the belts are on ok. What else should I look for?
I had the same problem. I found that when I took the belt door off, the belt was fine. I turned it over and took the red retainer arm out and then removed the screw on the white brush holder, the toothed belt was fine also. Somehow the machine had grabbed a carpet cord and wrapped it around the pulley where the toothed belt and the flat belt both attach. The spindle just wouldn't turn. After removing the carpet thread, everything worked fine again.
Jan 07, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do i put new belt on
Here is a link to the manual and to the belts you need. hope it helps!
Bissell ProHeat Manual and Belts
Nov 21, 2009 | Bissell 7901-R Clearview Proheat Plus...
My bissell steam cleaner clear views keeps
heatman101
ghhg
Nov 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cannot figure out how to install brush belt on a bissell proheat
heatman101
twywt
Jan 16, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
164 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
