I have a goodmans gdvd60lcd with 5'' tft screen and it stop turning on
Do you know goodmans gdvd60lcd
Does anyone know if I can use a Goodmans TFT LCD TV, Model: GTVL19W19HD as a computer monitor? It has a VGA socket on the back, but when I connected a computer It wouldn't show.
Yes,
You will need to select the VGA or PC input on the TV and then boot the PC up with the monitor attached so the video card will see it correctly.
Nov 07, 2012 | Goodmans GTVL19W17HDF 19 in. LCD TV
No cd rom g-shot goodmans 3022 tft
Hi there, I am very embarrassed that I had a Goodmans G-SHOT 3022 which I gave to a charity shop but I still have the CD so if anyone wants the CD please reply with your address and I will send it.
Feb 28, 2012 | Goodmans G-Shot 3022 Digital Camera
My goodmans TV/DVD model GTVL19W17HDVF about 18 months old has stopped loading CD's or DVD's. the TV works fine and the cd's will load into the unit but will not move on from the loading icon on the screen
Have you tried unplugging the unit, and waiting for 5 minutes and then restarting from the FIRST TIME setup screen. If you do that and then get a can of liquid air cleaner spray and blowing the area inside the slot with the cleaner and then reloading a disc that you know works. If this does not work then the reader transport mechanism is probably pooched
Nov 15, 2009 | Goodmans GTVL19W17HDVF 19 in. LCD TV/DVD...
Goodmans G-Shot 3029 TFT Can I Download software to use this camera?
Hi agchappell,
Download your software here:
http://download.driverguide.com/driver/G-Shot+3029TFT/Goodmans/d1039267.html
Regards
R.K.
Oct 21, 2009 | Goodmans G-Shot 3026 Digital Camera
Goodmans gtv42 p4
change your backlight or tft light
Mar 20, 2008 | Goodmans W280NS Television
Screen retracts, then opens, and retracts, and does not stop
I had that problem too I'll I did was press the reset butoon on my unit and everything resetted but the bypass code, you have to reprogram your stations and the time thats it
Mar 20, 2008 | Jensen's VM9312 Car DVD Player
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Need driver for GOODMANS G-SHOT 2025 TFT
i have a goodmans g-shot2025tft
i am unable to find my installation disc.
its pretty difficult for me to use the digital camera.
pls help
anya esq
Feb 01, 2008 | Goodmans G-Shot 2025TFT Digital Camera
Monitor stops display
most likley the monitor has an internal power supply failure, generally the cost of repair could be higher than buying a new one.If your monitor is still in its warranty period contact the manufacturer,if not do you know of a local tv repair shop that provides free estimates to confirm cost of repair vs. replacement?
Dec 14, 2007 | ViewSonic VA1703wb Monitor
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
