Question about Whirlpool GD5SHAX Side by Side Refrigerator
Bad fan I cleaned my coils and aimed a regular fan, which cooled the strip between the doors (whirlpool Gold GS6HAXLL03) When I stopped the fan it heated up again, so your answer was right on. How hard do you suppose it is to replace the fan. Or could it be something else, i.e., some fan associated device?
  • 218 Answers
The condenser fan - the fan which blows across the coils outside the fridge - should be running any time the compressor is running. If you hear the compressor but don't feel air moving under the unit, then the condenser motor is probably bad. It's not hard to replace. Find a replacement motor at a parts store or website like www.repairclinic.com . Some of the fans come with instructions, but it should be easy to figure out. Just be sure to unplug the fridge before you start.
Posted on Sep 07, 2008
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
Hot strip between doors
First , remove the bottom kick plate , and vacuum the coils . They have to be clean of dust , lint , pet hair , etc . Then pull the refrig out , and remove the lower panel , to expose the compressor and cooling fan . This fan HAS to be working , to cool the compressor AND the coils . If not running ( fan ) , check for an obstruction of paper , insulation , etc , and remove the cause . If not being obstructed , and not running , replace the fan motor . Afterwards , be sure to reinstall the back panel , as this panel , helps pull the airflow across the coils , and compressor . The strip between the doors , has part of the coils behind it , and will get hot , if the coils in front are dirty , or , the fan behind the refrig is not working .
Dec 04, 2009 | Whirlpool Refrigerators
Whirlpool Gold GD5RHAXNQ00 refrigerator not cooling properly.
It takes time for the temp to adjust(up to 24hrs) If the door is open a lot(looking into the box) or the door gasket is bad this will contribute to your problem. Are you sure the thermometer is good that you are checking the machine with. The thermistor could be bad as well(the control that senses the actual temp
Nov 03, 2009 | Refrigerators
Our refigerator works on and off. Cools fine for a few days and then compressor stops. Wait 24 hours or so and then it works again.
Look under it for the cond fan to not be turning, find the condencer fan pulg it up and see if it comes on. If not she is bad and needs to be fixed, untill you can find a fan to fit. get a small fan from the store and aim it at the coil, clean the coil good so air can flow.
Sep 10, 2009 | Refrigerators
Center front partition is very hot!
Either your coils are dirty ( clean from the front after removing the kickplate , only what you can get to ) or , the condensor fan motor is bad ( motor which cools the compressor ) .
Jul 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My freezer is working but fridge has stopped any ideas in what could be wrong. The coils where dirty I have cleaned them..
Does this unit just have one thermostat? is this a frost free unit? does the cooling for the fridge come from the freezer side compartment via internal fans, if so are they working?
well done on cleaning the coils by the way, did you notice the fans down there running and latent heat being dispersed? (FROM COIL)
Jun 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My whirlpool side-by-side is getting hot on strip between doors but everything seems to be working fine. Is there a solution? What if it becomes extremely hot??
It will not become extremely hot. It is heated by a thing called a mullion heater. It warms the area so it doesn't sweat and mold in the summertime. It is perfectly normal.
May 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Heat strip is to hot on freezer door frame whirlpool frige sxs.....
Two things can cause this:
1. Dirty coils.
2. Bad condensor fan motor (this cools the coils). The fan motor can be accessed from the back by removing the lower panel.
Dec 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Refrigerator
When this area gets very hot, it's usually because of inadequate air flow across the condenser coils under the refrigerator. Check to see if the condenser fan has stopped blowing underneath. Remove any obstructions or replace the fan motor if it has stopped. Also clean any accumulation of dust from the coils. The refrigerant line runs down the divider at the front of the unit to warm it slightly and prevent condensation and/or frost there, but it should not be noticeably hot.
Jul 28, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
