Question about Maytag Dishwashers
I had maytag food waste disposer model fb10-20 for 10 year and works fine so far, but all of sudden it stop working. i tried with reset button but failed.
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
  • 3 Answers
SOURCE: Whirlpool Dishwasher Not Working
Did you check the fuse in the plug (or fused spur) for the dishwasher?
Posted on May 17, 2008
  • 161 Answers
SOURCE: Maytag Dishwasher Model DWU9200BAB
Do you have an air gap between the disposal and the dishwasher? If not required raise the hose and as high as you can. It must be above the water level in the sink. Try attaching it to the underside of the counter. At some point the hose should be above 32 inches. It the problem is with the dishwasher itself. Don't fix, replace. They are not really designed to last over 10 years. The new ones , especially in the last year or two are a BIG improvement over any older one. So quiet you can't tell they are even running, they clean so much better and are much more energy efficient. Stainless steel interiors are just a fad. The plastic tubs are actually less likely to leak and are by there nature more quiet.
Posted on Jul 03, 2008
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
SOURCE: Control Panel not working
I had the same problem with my dishwasher. I have model number kudso2frss4. My husband and Father-in-law checked all the electrical and they were all fine. They found that the high-limit tub thermostat was bad. They bypassed it with a wire until the part comes in. It is working great now. Hope it helps good luck
Posted on Jan 08, 2009
It stopped spinning but the motor made a buzzng noise, then it just stopped all together, now nothing
1) Copy following link for troubleshoot tips and instructions how to install new disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) Once the motor stops spinning, it will begin to overheat, and that will trip the thermal reset button.
Push reset button located bottom of unit, then rotate disk with broomstick. If motor will not work, then replace unit.
Feb 05, 2013 | In-Sink-Erator InSinkErator Badger 1 1/3...
Food waste disposal stopped working
Push reset button located bottom of disposal.
Check breaker is ON.
Copy following link for steps troubleshooting garbage disposal:
Nov 01, 2012 | Home
Is there an override button is not clearing garbage
If disposal is not running, then push red reset button located bottom of disposal.
If disposal is clogged, Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal.
Oct 19, 2012 | Badger 1 Insinkerator 76039h 1/3 Hp Feed...
Maytag FB20 Food Waste Disposal Unit Magnetic Drain Plug no longer actuates the on switch Power is good, reset is in, magnets in plug still pull when tested. Can i instal a new switch
Sorry to read about your problem, I hope this helps you out.
their are no replacement parts for your unit, the whole unit has to be replaced.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Maytag DFC1500A Continuous Feed Food...
Won't run
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Sep 25, 2010 | Maytag DFC5500AAX 3/4 HP Continuous Feed...
Water drains fine the unit runs but does not get rid of food
Be aware that your selected object you have a problem with is a hot water faucet made by insinkerator, not a disposer. I'm not sure what your problem is, but let's try to address the most common problems.
The disposer must be turned on and run to get rid of food. Does the motor come on when you turn it on? If it doesn't, does the disposer make a humming sound when you turn it on like it's jammed? If it makes no humming sound when you turn it on, first press the reset button on the bottom firmly. If the disposer then makes a humming sound, it's jammed. Read below. If the disposer still doesn't act like it has power when you turn it on, check the circuit breaker or fuse and try the reset button again. If none of this so far works and you still don't even hear it making the motor-stalled-buzzing-sound (open the cabinet door) then you should still check the disposer to see if it's jammed.
First, make sure you TURN OFF THE POWER to the disposer with the circuit breaker or fuse box. Now you need to check if the shaft rotates freely. On most disposers, there's a hole in the center of the bottom of the unit. You can insert a special disposer wrench or allen wrench into this hole and turn the shaft of the motor. It should rotate freely. You'll probably find the disposer wrench taped under the sink, or you can pick one up at a hardware store. If the disposer doesn't have this hole on the bottom, you need to go from the top. Remove the splash guard (black flappy thing) if it is removable on your model. Look inside with a flashlight for anything foreign that may be causing a jam like bottle caps. Place a broom handle against one of the lugs mounted on the wheel, and see if the wheel turns freely. If it doesn't, try to work it back and forth until it does. Then use tongs to remove the foreign object. After you clear a jam, it may be necessary to push the reset button again. If the motor became overheated it may take it as much as like 20 minutes for the motor to cool enough to allow you to reset.
Be aware that food usually needs to be pushed into the disposer manually, with a full flow of cold water.
Dec 09, 2009 | Dynamic In Sink Erator 41746 HOT-1...
Warranty Information
appears to be an entry level and as such probably a year or less
Jun 28, 2009 | Maytag DFC1500AAX 1/2 HP Continuous Feed...
Dishwashers Logo
80 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
