Question about Breadman TR555LC Bread Maker
Fruit & NUT ADD-IN BEEPER
I seem to miss the beeper when it is time to add fruit and nuts. Can someone tell me the time to add for cycle 6, sweetbreads?
2 Suggested Answers
daryl441918
  • 1280 Answers
SOURCE: I put fruit in the fruit & nut dispenser &
Hi, sorry your dispenser appears not to be working. Unless and until you can repair it you can always add fruit and nuts the old fashioned way. Take a look at your manual and find the program you are using. Find how long the 2nd knead cycle lasts. For example lets say your 2nd knead last 20 minutes. Plan on opening the lid of your machine 10 minutes into the 2nd knead. All bread machines recommend add-ins well into the 2nd knead. Just have your ingredients premeasured on a paper plate next to the machine and fold the plate and pour them in halfway into the 2nd knead of the program you chose. At least that will help you get the bread you wanted.
Posted on Dec 30, 2010
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
How do i remove or disconnect the beeper on my pride mobility go go sport scooter? I have the manual and it's worthless - i need instructions how to do it - i repeat - pride mobility manuals are wort
hi ,the the cable that connects to the controller contains the beeper...
you can't miss it , putting a tape over it will quieten it down no end ...i don't recommend cutting cables , not required... you can't miss it , normally contained in heat shrink tubing ...
Regards
Rob...
www.gewizrepairs.co.uk
Dec 28, 2014 | Pride Go-Go Sport 4-Wheel
How do I turn the beeper off so there is not beep at all on my Oster 5834?
You need to look in your owner's manual to see if turning off the beeper is an option.
The beeper is very important to inform you when the bread is ready, when to add ingredients, or if there is a problem with the maker. I am not sure it can be turned off.
Jul 28, 2014 | Oster 5834 ExpressBake Bread Maker
Raisin & nut Dispenser is not retracting after dispensing fruit etc
The trapdoor feature on bread machines often malfunction. Once it starts happening the best thing to do is just add your raisins, nuts, etc. yourself about halfway through the 2nd knead. If you have one of the machines that just has one long first knead then add them at 7 minutes before the end of the knead. daryl441@msn.com
May 11, 2014 | Panasonic SD-2501WXC Automatic Breadmaker...
Turn signal flasher not loud enough
see previous poster, where he begs more quite.
in your case, add a 12vdc beeper to the dash flashing indicators.
if you have 2 indicators, add 2 diodes to the beeper , ask.
the best way is at the flasher, ( 2 diodes and beeper.)
beep minus to ground
beeper plus to 2 cathodes (band) 1N4004 diodes, (ubiquitous part) and the each ANODE to each side of flasher Left and right.
bingo , it makes more noise.
i can do a schematic easy, ask.
Mar 24, 2014 | 1999 Jeep Cherokee
3 beeper beeped at 300. The beepers beep @8,10,and 12 minutes respectively. What time will the beep at the same time again.
If the beeper beeped at 300 then it will beep at the Lowest Common Denominator. The LCD for 8, 10, and 12 is 120. So add that 120 to 300 and you end up at 420. The Beepers will next Beep at 420.
Feb 28, 2011 | Computers & Internet
I put fruit in the fruit & nut dispenser & it did not come into the bread. What am I doing wrong?
Dec 30, 2010 | Breadman TR2200C Ultimate Bread Maker
The additional ingrediets beeper is not beeping. My machine is relatively new.
If you have your manual there is another way to handle the add-in beep. Find the page that shows the lengths of each program. The programs that have the add-in beep usually show the time that it occurs. So if you watch your timer you'll know when its close.
Sometimes I just set the timer on my oven because it is much louder than the bread machine alert and it doesn't stop until I turn it off, unlike the bread machine which shuts off after a few beeps.
Just synchronize your oven timer with the timer on the bread machine.
Example:
with my machine my manual says that when the timer says 2:35 the beep will sound with the sweet bread program for a 1.5 lb. loaf light crust. I just take the subtract that from the time of the total program and set my oven timer for that time. When I hear the oven timer go I add my fruits, nuts, etc.
Dec 20, 2010 | Black & Decker Bread Machine
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Crispy corn
1/2 cup butter 1/2 cup brown sugar 3 quarts unsalted popped popcorn 1 cup chopped walnuts
Cream together butter and brown sugar till light and fluffy. In a separate bowl, toss popcorn and walnuts. Add creamed mixture to popcorn and nuts. Combine until coated. Spread on a large baking sheet in a single layer. Bake at 350-degree oven for 10 minutes or until crisp.
Yield 3 quarts
(based on a 1-cup serving) Total Calories 189.5; Fat 15.2g; Carbohydrate 12.8g; Sugar 5.7g; Fiber 1.5g; Protein 2.2g; Sodium 75.5mg; Cholesterol 19mg
Feb 06, 2008 | Gold Medal 2102E Deluxe Citation Popcorn...
Breadman TR555LC Bread Maker Logo
24 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
