Question about Bosch SHU9916 Dishwasher
Will not shut off at end of the drain cycle
Dishwasher seems to drain but will not shut off.I tried to reset it by unplugging it but it does nto reset and no water goes through the cycle.
    Novelist:
  • 196 Answers
There should be a float behind the fill valve with a magnet in it which operates a reed switch. This switch keeps the pump running as long as the base has water in it or if the float is stuck on the up side (and makes the pump "think" that there's water in the base). Check this float to see if it's stuck and release it so it could tell the pump when to stop draining. Hope this solves your problem.
Posted on Jan 31, 2006
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
GE dishwasher won't drain or cycle
TRY TO UNPLUG THE UNIT FOR AN HOUR TO RESET THE ONLOAD SETTING THAT PROGRAMMED INTO IT..
KEEP ME UPDATED
Sep 28, 2008 | Dishwashers
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Dishwasher wont completely drain and turns off
I understand that your Frigidaire dishwasher shuts off near the end of the cycle, leaving water in the bottom of the tub. I also see that the display is going black. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. When power is restored, run any cycle. If you are still noticing your dishwasher shutting off towards then end of the cycle and water being left in the tub, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off and not drain. Hope this is helpful.
-Best regards-
WP
May 14, 2014 | Frigidaire Dishwashers
How do i reset my whirlpool adg 7460 dishwasher ? programme seems stuck on end cycle?
Unplug it, move timer to start and plug back in. If it still seems stuck at the end it is almost certainly the timer. If it starts as normal, suspect the drain pump or pressure switch
Apr 22, 2012 | Dishwashers
Our dishwasher will not drian out all the way. I cleaned out the screen and sump and it still does not drain out all the way. I also ran the unit and waited for the drain cycle and it seemed to flow...
hi Richardcr1.
After having examined many dishwashers that were replaced because they wouldn't drain, the largest percentage of them were simply because of a clogged drain hose or pump strainer. Too many people seem to think that the dishwasher is first cousin to a garbage disposal. It is not.30 Apr 2010
SOLVED: Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/Answers/View/.../Does+not+drain+the+water+at+the+end+of+cycl...
How do I fix my dishwasher that will not drain?Check for a clog:Make sure the kitchen sink drain is not clogged.If a disposer is installed, run the disposer to clear the drain system. Do not put hands into the garbage disposer. ...If an air gap is installed, remove the cap and remove any debris. ...Do not use drain cleaner in the dishwasher.Dishwasher Does Not Drain - Products - GE Appliancesproducts.geappliances.com/appliance/gea-support-search-content?contentId=16240Search for: How do I fix my dishwasher that will not drain?
Nov 29, 2017 | General Electric Dishwashers
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Contunuous draining turned into a flood when unit powered off
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
May 09, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
Dishwashers Logo
422 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
