Question about HP Pavilion ze4125 Notebook
Systems restore for windows xp
Tried restoring my computer because i thought i had a virus. used the disks and during disk one gave me error code 1802 image file in ivalid or corrupted
Power connection to computer came out during shutdown yesterday. Today, turning on, it will not boot up.
You are going to need a clean boot up disk. You will have to get one mailed to you or you will have to use another computer to download one. This will get you back into a point that you can do a windows restore. This is going to get rid of all programs and start you fresh. I do, however, feel that you disk drive is going out or already shot. You should do a Chkdsk on it. (check disk). This will tell you if it is a hard drive error or not.
Jan 09, 2015 | Computers & Internet
I have a emachine computer(window xp), when trying to do system restore error msg "windows/system32/webm/webmcont.tlb could not opened", stops at 32% restore. I do not have restore or back up disks. I'm...
Try to Boot on safe mode and check if you can do a system restore there and hopefully you wont have that error message , but if still have that error you can try to run your recovery disc to recover that missing file....
Oct 15, 2008 | Computers & Internet
Toshiba satelite error message0xc00000e9. how do I fix it?
Error Code: 0xC00000E9
Error Translation:BERR_DUPLICATE_PROXY
Problem: Unable to process object %1 because the specified e-mail address %2 has the same type as one or more other e-mail addresses specified for the same object.
#define BERR_DUPLICATE_PROXY 0xC00000E9L
Source: Microsoft Support
solution:
Restart the laptop, and then press F8 to enter the Windows Advanced Options Menu, and select Safe Mode,
then fix your email address
Sep 24, 2011 | Computers & Internet
When i start my pc today, i had stop 0x0000007b (0xf9e48528 0xc0000034 0x00000000 0x00000000) i try with chkdsk /r end fixboot but no result.
When you start your computer, you may receive one of the following error messages:
  • STOP: 0x0000007B (parameter1, parameter2, parameter3, parameter4)
    INACCESSIBLE_BOOT_DEVICE
  • Setup has encountered a fatal error that prevents it from continuing.
    Contact your product support representative for assistance. The following status will assist them in diagnosing the problem.
    (0x4, 0x1, 0, 0)
    Setup cannot continue. Power down or reboot your computer now.
You may also receive a "Stop 0x0000007B" error message during Windows XP Setup when the Setup program restarts during the installation process. When you receive a Stop error while the Setup program is running, you receive the second error message. To troubleshoot this issue, read the following four sections to determine if any one of the issues applies to you. If none of the issues apply to you, use the following general troubleshooting steps at the end of the article. uparrow.gifBack to the top Boot-Sector Viruses You may receive a "Stop 0x0000007B" error message if your computer is infected with a boot-sector virus. If the problem is intermittent and you can start Windows, check your computer for viruses. If you find a virus, also check any floppy disks for viruses before you use them again.
For a list of antivirus software manufacturers, click the following article number to see the article in the Microsoft Knowledge Base: 49500 List of Antivirus Software Vendors Note You may have to use more than one brand of virus-detection software to detect and remove various viruses.
Important If your computer has been infected, it may be open to additional forms of attack. We recommend that you rebuild infected Internet-facing servers by following the guidelines that are published on the CERT Web site. Internet-facing servers are servers that function without a firewall or other protection. It is also a good idea to rebuild any other computers that are at risk because of their proximity to infected computers before you put them back in service.
If a virus has infected your Windows XP-based computer and a virus-detection program cannot remove the virus and repair the system, you must repartition and format your hard disk and reinstall Windows XP. For additional information about partitioning and formatting a hard disk with Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 313348 How to partition and format a hard disk in Windows XP For more information about how to help protect the boot sector from viruses in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 122221 How to protect boot sector from viruses in Windows uparrow.gifBack to the top Device Driver IssuesYou may receive a "Stop 0x0000007B" error message in the following scenarios:
  • A device driver that the computer boot controller needs is not configured to start during the startup process.
  • A device driver that the computer boot controller needs is corrupted.
  • Information in the Windows XP registry (information related to how the device drivers load during startup) is corrupted.
Windows XP requires a miniport driver to communicate with the hard disk controller that is used to start your computer. If Windows XP does not supply a device driver for your controller or if Windows XP is using a corrupted or incompatible driver, you must replace the driver with a valid copy that is compatible with your controller and Windows XP.
During the first phase of the Windows XP installation, Setup displays the following message at the bottom of the screen: Press F6 if you have to install a third-party SCSI or RAID driver. Press F6 and then follow the instructions to install a mass-storage device driver from your Original Equipment Manufacturer (OEM). For additional information about using F6 to load an OEM device driver to support, click the following article number to view the article in the Microsoft Knowledge Base: General Troubleshooting If none of the issues that have been described in this article apply to you, use the following general troubleshooting steps:
  1. If you receive one of these error messages while you are installing Windows XP, update the computer BIOS or obtain Windows XP drivers for your hard disk controller (from the manufacturer of your computer, system board, or hard disk controller), or do both. For information about how to update your computer's BIOS or obtain Windows XP drivers, contact your computer manufacturer. For additional information about the availability of drivers, see the Device Driver Issues section in this article.
    Note: If Windows NT 4.0 or Windows 2000 was installed previously on a mirrored boot partition, see the Other Issues section in this article.
  2. Use the Last Known Good Configuration feature. This may resolve the problem if you recently installed an incompatible device driver for your boot controller. For additional information about using the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 How To start your computer by using the Last Known Good Configuration feature in Windows XP
  3. Use the Repair option with Windows XP Setup. For additional information about repairing Windows XP by using the Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 315341 How to perform an in-place upgrade (reinstallation) of Windows XP
  4. Restore a registry backup. For additional information about restoring a registry backup, click the following article number to view the article in the Microsoft Knowledge Base: 307545 How to recover from a corrupted registry that prevents Windows XP from starting
May 18, 2011 | Computers & Internet
Computer not working. tried restore says error stopped it from working. facebook apps won't work. says to download flash version. tried said downloaded but still won't work. try to get on some web pages...
Sounds like your hard drive has unrecoverable errors. If you have another computer available, download SeaTools for DOS and copy it to a CD. Boot the problem computer from the CD and it'll run a check to see if you harddrive's smartcheck flag has been tripped. If it has, replace hard drive and restore the factory settings using restore disk(s). If you don't have the restore disk(s), you can order them from Toshiba for your model for about $20.
If hard drive checks out w/out errors, you may be suffering from a virus that has corrupted files. The easiest and fastest approach is to restore to factory settings using the restore disk(s). If you haven't backed up your important data, download AVG with another computer, put it on a CD, install it on the problem computer, if possible, then start the problem computer in Safe Mode, then run the AVG program. It will default to batch mode when run in Safe Mode. If you have viruses, it'll get hundreds off your computer during the batch run. You may have to turn off Windows' System Restore first, to ensure the viruses don't get reloaded.
Feb 05, 2011 | Toshiba Satellite Pro L300 Notebook
My computer is running slow.
Many factors may cause your Windows 7 running slow: lack of memory, useless programs, wrong startup settings, junk files, registry redundancies, viruses or spyware and more.
If you computer is running slow or starting up slow, you may visit this article to learn more.
Jan 09, 2011 | Computers & Internet
Runs extremely slow-maybe 5 or 10 minutes to load up at start get "not responding" on intertnet or mail connections slow response if selecting e-mails freezes during typing McAfee Security shows...
try to run your computer with your Antivirus disabled temporarily
>if it runs faster then it is an issue with your anti virus but there only is a slim chance that this a security issue, but it's worth trying it.
if system is still slow:
>Try optimizing your browser by going to Internet Options on Control Panel
>click on Delete Files check the box that says DELETE ALL OFFLINE CONTENT and Delete Cookies under General tab
>Go to Advanced tab click on Restore default Settings or Restore Advanced Settings
>click Apply
>if this doesn't work,do a Disk Cleanup,Disk Defragmenter, or System Restore follow these steps:
>click on START
>click ALL PROGRAMS
>click ACCESSORIES
>click SYSTEM TOOLS
>click Disk Cleanup / Disk Defragmenter / System Restore
(these 3 tools are all on the same folder)
*****System Restore will be the last resort. this sets your computer back to the date when you know your computer was working perfectly fine.
Sep 19, 2010 | Microsoft Windows XP Home Edition
I have a malicious virus...i tried Windows update virus removal..still have the block from accessing internet, asking to buy removal tool...tried restoring to factory settings upon restart..F10 doesnt...
jimmy_jon430
In regards to removing the virus when you did the factory restor did you actually to the restore of the restore partition on the hard drive or from restore disks. If it was from the restort partition it is possible that the virus spread to that drive.
If you have access to another computer then I would connect the drive to other computer and try to scan the drive.
The reason for this if Windows thinks the virus is a system file the removal program can not remove it if Windows is running. So connecting it to another computer allows you to fully clean the hard drive. However with alot of viruses at this level will cause you to have to do a clean reinstall of Windows any ways. So you may have to look using your restore disks any ways to get a clean reinstall of Windows.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 05, 2010 | Microsoft Windows XP Professional
Are certain restore disks interchangeable?
Unfortunately you cant use a vista restore disk for a XP operating system.
You could install vista on it and then use XP compatibility mode for whatever programs you want to run. Simply right click on the program and select the compatability tab..change to XP.
Apr 24, 2009 | Computers & Internet
Need system restoration
You can restore your computer to an earlier date by using system restore. click-start-all programs-accesories-system tools-system restore. Than follow directions.
Dec 28, 2008 | Averatec AV4155-EH1 PC Notebook
HP Pavilion ze4125 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
