Question about Brother MFC-9440CN Laser Printer
Replacing Toner My Brother MFC-9440CN wil not print even in black ink. It says yellow toner life end. Do I have to replace all of the toner cartridges for it to print even the black?
Nope, just replace the one it says is end of life and the it should work again. It seems brother has a built in mechanism that when ONE of the toners go empty it prevents the whole machine from working.
In my experience, get either the HIGH yield brother originals or learn how to refill them yourself. Anything else like remanufactured toner or the low yield version are not worth it.
Posted on Jan 06, 2009
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Posted on Sep 26, 2008
Brother MFC 7820N, I am getting "Toner End Life"
I fail to see why you are covering up the toner sensor led's when you have a new cartridge fitted?
Also if you are using a recycled toner from a very well known uk shop that refills toners and ink then you may well have broken the drive gear that stirs the toner. i have seen this six times and their toners do this.
It could well be one of the pitfuls of recycled toners.
Jul 24, 2011 | Brother MFC-7820N All-In-One Laser Printer
Tip
Brother MFC 9440CN Toner Life End Message... The Final Solution
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Having gratefully read elsewhere about how to defeat the toner sensor window with black electrical tape, I went to work.
Sadly, I was crushed to discover that performing this operation did not solve the problem for my accursed unit.
[Do it anyway as it will save you from these annoyingly premature warnings in future!]
Reading further, I became convinced that a reset process similar to that used to solve this problem for the Brother 2040 and 7420 models was also required here.
With nothing more to go on than responses to my emails from the good people (knuckleheads) at Brother telling me only how to install a new cartridge, I began poking around on my own 'till, after much swearing and gnashing of teeth, I figured it out:
1. With power on, open the toner access main door (You will get a "door open" message in the LCD.)
2. Hit the "Clear/Back" button and... ta-dah!!! you go right to the “Toner Reset Menu” (cue Vienna Boy's choir sounds here).
3. Using the up á Down â "Search" arrow buttons you can then scroll through reset options for each of the printer's [4] toner cartridges!
Code: B. = black; C. = cyan; M. = magenta and Y. = yellow
4. For each for these cartridges is the option to reset for low yield = S (small?) or High Yield - H
5. Using the number keypad, select option #1 (to reset each to the size you have installed.
6. Hit the "Clear/Back" button to get out of the menu, close door ad the problem is FINALLY solved.
Additional tip: you might want to try turning on the Toner Save Mode to stretch out your cartridge replacements.
Open Printers > go to the MFC 9440 icon >>> Printing Preferences...> Advanced Settings > Printer Functions > Toner Save Mode >> turn on.
Looks fine to me, though not suggested for grayscale or photo printing,.
Cheers!
b.
on Jun 30, 2008 | Brother MFC-9440CN Laser Printer
Brother HL 3070CW says the toner is low and won't print. It has toner and I have to get something printed for a client
I done on my brother lh3070cw printer cartridge on Message "Low Toner"
First I take off toner cartridge
second - Covered the both Glass Buttons of Cartridge situated right and left side of cartridge (all cartrideg) for Black Electric Tape.
thent install the cartridge in the printer again.
after install the cartridge press SECURE PRINT AND CANCEL BUTTON SAME TIME AND CLEAR THE STR AND STD FOR PRESSING ok BUTTON FOR 2 TIME.
ERASE EACH STR AND STD
THEN PRESS CANCEL
YOU CAN USE YOUR PRINTER FOR END OF THE TONER
Mar 28, 2011 | Brother MFC-9440CN Laser Printer
My mfc-9440cn prints a black line on the rigth side do you know what could that be? maybe needs new drum?
Hi there !
If you are self refilling the toner cartridge, the roller drum can be damage due to wear and tear. I need to replace new toner cartridge other i will getting wider and wider on both left and right of the paper.
Jan 13, 2011 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer is saying toner life end and I just put a new cartridge in.
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Nov 11, 2010 | Brother MFC-9440CN Laser Printer
Brother- MFC 90CW black ink just replaced, but not printing, even the test print didnt print propaerly, it came out very light in other colours but not in black? what to do? is it a toner problem?
Thoughout my experience of fixing computers, I have seen this happen twice. Once was because the "new" ink cartridge was empty (which should cause the LCD display to say "cannot print"). the other was because the end user did not remove the protective yellow cap before installing the ink cartridge (yes, they made it fit). If neither of these are the cause you should try cleaning the print head. You can do so by pressing "ink", then scroll down to "cleaning", then scroll to black and press "ok".
Nov 06, 2010 | Brother MFC-5890CN All-In-One InkJet...
How do I set Brother 9440 MFC to print using black cartridge only?
You can set the MFC-9440CN to print with the black toner cartridge only through the printer drivers.
If you are using Mac, this needs to be changed before you print or set a preset.
If you are using windows, follow the below steps.
1. Go to Start menu \ Control Panel \ Printers (devices and printers for windows 7)
2. Right click on the MFC-9440CN and select "printing preferences"
3. Under the "basic" tab, you will see "color mode"; simply select "mono"
Thank you,
Mar 28, 2010 | Brother MFC-9440CN Laser Printer
My yellow toner is out and the printer will not print in just black
The MFC-9440CN should be able to work even if one or more of the color cartridges are empty.
here's what you can do to print in black only.
1. Unplug the power to the MFC-9440CN
2. Clear the print queue on your computer so that there are no jobs waiting.
3. Right click on the MFC-9440CN printer icon and select "printing preferences"
4. Select "mono" as the color mode.
5. Turn the power back on for the printer.
Now when you print it will be in black only and it should work even if all 3 colored toner's are empty.
Thanks,
Pat
Mar 26, 2010 | Brother MFC-9440CN Laser Printer
Brother MFC-9440CN Laser Printer Logo
1,189 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
