Question about HP NetRAID-2M SCSI Controller
NetRAID-2M hangs out while initializing HDDs
Hello support, I recenttly bought an HP NetRAID-2M that hangs out while trying to initialize HDDs, it did not let me enter controller BIOS, once the cable SCSI cable is connected to HDDs, if cable is not connected, the BIOS can be configured through Ctrl+M combination. My board is an ASUS P4S800D-X, my hdds are seagate cheetah st173404lcv, they are working properly as well the motherboard, scsi cable and terminator since I already tested with an IBM ServeRAID that I already own. The problem takes place after the controller start to scan for devices, I found this in HP support pages: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=51930&prodTypeId=329290&prodSeriesId=51930&objectID=lpn12570 which describes the problem I have as well as links and recommendations about how to upgrade the BIOS & Firmware of the controller as well as some HP parts that are present in some SCSI hdds including mines, I already flashed the controller sucessfuly and I downloaded firmware update for HDDs but HP support removed the procedure about how to upgrade the HDDs firmware, if the controller hangs out how could I be able to boot using the floppy disk, the controller BIOS never give back control to motherboard BIOS which violates the following BBS principle: ... 6.2 PnP Option ROM Initialization It is a requirement for all PnP option ROMs to return control back to the BIOS after they have completed their initialization. If a PnP option ROM does not return, it takes control away from the BIOS and foregoes compatibility with the BIOS Boot Specification. ... in the above mentioned link they make reference to the following link: http://h20180.www2.hp.com/apps/Nav?h_pagetype=software&h_lang=EN&h_cc=US&h_product=hpfirmware19319 to find information on how to update HDDs firmware, but the link in that page does not work. Any help will be appreciated, Best Regards, Orlando Otero
  • 3 Answers
Here's a link to the fireware update tool you need to do the flash: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=329290&prodSeriesId=65146&swItem=ns-9915-1&prodNameId=19319&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0 As for never getting the chance to boot from the floppy drive to update the drives, try using the ServeRAID controller just to flash the drives then put the NetRAID-2M controller back in.
Posted on Feb 19, 2006
Hello mate. i have server hp proliant ml350 g5, when i buy it ,it works ok. when i replace the HDD from 250g to 80g the system doesent work anymore. i wont to install windwos server from begening but says...
Are the hard drives connected to a RAID controller? If so you will need to configure the disk in the RAID BIOS and initialize them.
It is likely that the Windows installer still will not recognize the drive because you will need to provide the drivers to the RAID controller during the installation process.
Aug 09, 2012 | HP Compaq ProLiant ML350 G5 Server
HP 4650 hangs at initializing
Remove the jetdirect network card. Then power it on and see if it goes ready. If it does then it could be a fault with the jetdirect card
Oct 06, 2009 | HP LaserJet 4650 Color Printer
Had a problem with HP Photosmart C5180 All in One says cartridge cannot be used after initialization. Cannot find telephone number to ring HP in Ireland for support. This happens every time. I just had a...
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
Sep 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
HP Proliant ML370 Server i have problems solving this server problem. When you turn on the server it tries to initialize and come up. But after a while it gives a beep sound, this sound is like that of a...
Remove all the cards except dispaly from the slots,disconnect all  hdds and start the server in minimum hardware and check.reset bios .Is there any LEDs in the mother board is glowing amber or red colour??Please try these diagnostics.
Oct 29, 2008 | HP Compaq ProLiant ML530 Server
Raid degraded
If you are running a Intel processor, please go to the Intel site and use their free scan for Intel drivers utility. Install an updated RAID controller and then try to sort out the issue using Device Mgr.
Sep 02, 2017 | HP NetRAID-2M SCSI Controller
Raid config problem
download a driver over the net
Feb 21, 2008 | HP NetRAID-2M SCSI Controller
Open Questions:
Cloud Storage - Online Data Storage ' Dataalign Cloud Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
May 24, 2018 | VIA Computers & Internet
See all HP NetRAID-2M SCSI Controller Questions
HP NetRAID-2M SCSI Controller Logo
5,025 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
