Question about Uniden 5.8GHz Dual Cordless Phone
Dial mode; `tone/time break `and `tone /earth`
What is the difference between the two?and which is the best to use on a uk talktalk phone line?
i have a bt synergy 4500 cordless phone
thanks
SOURCE: set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Posted on Oct 28, 2008
SOURCE: we have a bt synergy 4500
It sounds like you're pressing the green button when you pick up the phone - when the phone is in the charger and you pick it up to answer it you'll be speaking straight away, no need to press any buttons.
You can toggle between speaker and the phone by pressing the green button.
Hope this helps...
Posted on Dec 27, 2008
divatif
  • 39 Answers
SOURCE: No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Posted on Mar 20, 2009
SOURCE: My BT Verve 450 digital phone set won't ring out /incoming call
My GE cordless handset won't ring when it's on the base charging but it will when I take it off. I've taken off the battery and disconnect the phone from the wall to try to reset it, but it still doesn't ring.
Posted on Nov 19, 2009
The phone display says check phone line?
If you have dial tone then the part of the phone that senses the line is malfunctioning. If you do not have dial tone, (more likely. then check your phone cord, phone jack (try using a different jack or cord or you can test the ones you are using with a different telephone). Most likely there is some sort of short circuit or break in the phone line preventing the phone service from reaching the phone base.
May 13, 2014 | Panasonic KX-TG5210 Cordless Phone...
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
We have a no line message, and are not recieving phone calls. How do we fix that?
You need to find out where the fault is. I like an old corded phone for this. Check if a different phone gets a dial tone at the jack and other jacks inside the building. If no dial tone inside, find where the phone service comes in. Open that box and if it has a RJ-11 connection, check if you get dial tone at the junction. (If you have an older service, you will need a special line tester to check the service.) If you have no dial tone at the service box, contact your phone company - there is a problem with the service. (It could be some idiot damaged a wire digging or something else.) If there is a dial tone at the service connection, you need to find the break in your inside wiring. Open up the jacks and check any visible wiring for loose wires or damaged wires. If there is no obvious damage, you will need to look at the hidden wiring (a professional to do the work might be best).
Good luck.
(I've had dead phone lines outside the home from lightning (affected the DSL), an idiot road crew and one unknown malfunction. All of these were promptly fixed by the phone company technician.)
Jun 18, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Outgoing call does not connect when I dial the number
depends on the telephone exchange . Suggest switching to Tone signalling . MTDF - https://en.wikipedia.org/wiki/Pulse_dialing
Old technology- Pulse or Decadic Signalling - the line is broken by a relay contact or if even older a rotary dial manual switch contact - Dial a 9 you would break the line connection 9 times and send nine pulses.
Tone sends two frequency tones that encode the number that you selected and is a much faster dialing system and more modern method.
Oct 16, 2017 | GE 27906 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
My cordless phone is clicking when i dial.
Jeanne fist a background history lesson - there are two dialing modes in existence one is pulse or earlier on was known as decadic dialing. This is where the phone would break the connection a number of times to represent the number dialed. Remember the old dial phones that you would dial a nine and it would spin around back to its original position and would break the line nine times . Very Very slow way to Dial.
now to the 21st century - Tone dialing was invented also know as multi tone frequency dialing MFTD by sending two frequency tones numbers and symbols could be encoded to pass through the phone line quickly.
Solution
press menu / select option
select telephone settings
see picture below from user manual
Jun 18, 2017 | Vtech Cordless 6041 Phone
How can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
Jun 01, 2008 | Uniden 5.8GHz Dual Cordless Phone
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Uniden 5.8GHz Dual Cordless Phone Logo
473 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
