Question about Hitachi CM811 Plus 21 in. CRT Monitor
Color Adjustments How can you get into the menus to adjust the colors once you replace a CRT with a new one? There appears to be some type of serial connections for this. Is there an easy workaround.
Why would you want to change the color settings after changing a CRT? changing a CRT should not affect the color settings! please describe the nature of the problem with more details.
Posted on Jan 30, 2006
JVC AV-27S33 only displays black and white (Color gone) Menus are still in color!
Check its color system adjustments. It will be best to make a factory reset to this set. Just unplug the TV from AC mains wall socket, and re-plug it after 10 minutes of so. This must make your TV a hard reset. If this do not help you, the chroma section circuits of your TV need to be checked for fault/s. This is a skilled work, and it will be best to contact any experienced service technician.
Jul 04, 2012 | JVC AV-27S33 27" TV
Projection is messing up. Too much red and blue color.
A CRT projector requires Convergence and Color balance adjustments from time to time. These settings can drift. What you are seeing is a lack of Green color intensity. Do you see some pink in the 'whites'?
The Green CRT surface also burns off faster than the Red and Blue leaving behind the same appearance. As long as your Green CRT is not too burned by gaming or watching Golf and football, a local tv tech will be able to dial it in for you.
Jan 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Dell 720 won't print color, color ink cartridge missing
check to see if the color cartridge has the plastic tab on the cartridge. Remove and reinsert cartridge.
Sep 13, 2009 | Dell Inkjet 720 Printer
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Color Problem after replaced Circut Board
When you replace the entire board in a Zenith TV, you must make the adjustments to align the new chassis with the old picture tube. You must adjust the CRT bias and drives as well as the horizontal and vertical parameters. On the older boards there were controls on the main and CRT boards but on the newer boards the adjustments are made with the remote control after entering the service mode. Tune in the shopping channel QVC, set the color and contrast to minimum and lower the brightness until the picture is just visible. Set the CRT bias settings for a pure black and white image, then increase the brightness and contrast to get a very bright picture and if necessary adjust the drive settings so that the bright picture is pure black and white. Return the video settings to normal and then adjust the vertical and horizontal settings so that the info boxes on QVC are centered top, left and bottom. If you are not sure that you can do that right then have a qualified tech handle it for you.
Jul 23, 2007 | Zenith SY3572DT TV
Color adjustment for CM 811U
Hi, if you are referring to the replacement of the picture tube, then yes, the color will have to be adjusted. However this should have been done by the tech personnel who did the replacment with a color bar generator and alignment tools. You can also try pressing the degauss button on the monitor to see if the color balances back. Hope this be of some help. Good luck
Apr 25, 2007 | Hitachi CM811 Plus 21 in. CRT Monitor
Color problems
First adjust the contrast level 25 percent.Now see there is any improvement. If the performance is well there is a problem in video section. May be capacitor leakage like 180v supply filter, and coupling capacitor in video section.
Aug 13, 2006 | Philips 36PT71B 36" TV
Hitachi CM811 Plus 21 in. CRT Monitor Logo
57 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
