Question about Dell Dimension 5100 (D51L1) PC Desktop
DVD Burner not see blank disk
When I attempt to burn a DVD the drive is not seeing the blank disk. It tells me to put in blank disk.
  • rjprow Sep 16, 2008
    1. I'm using Roxio, Nero, and DVD Shrink.
    2. It has worked in the past.
    3. I've tried many blank disks.
    4. I have no problem burning audio CD's
    Thanks jb94
  • jb94 May 11, 2010
    Which software are you using to burn the DVD?
    Has it worked properly before?
    Have you tried using a different blank disk?
    Does the drive read disks (ie DVD movies, CD-ROMs) okay?
  • 55 Answers
Delete LowerFilters/UpperFilters
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
Posted on Nov 25, 2008
I have never burned a CD. I have need of burning two tonight. What do I do?
are you burning a cd or dvd? burning a cd is pretty will do most of the work for you. put a blank cd in your cd rom/ dvd burner drive. it will ask you what you want to do with the blank usually asks you to format the ok.....a blank box will pop up....drag and drop your files to be burned into the blank box.....once you are done putting your media onto the disc....eject the disk...before the drive opens a box at the bottom of the screen says that the disc is being prepared for use on other computers. when it ejects, it should be can try to put it back in to the cd drive and see if your data/media files are on the disc. burning a dvd is alot more you have software for burning dvd media? if you do, they have help me files and tutorials........some more good also shows good tutorial vids on burning. just type in "burn a cd or dvd".
Oct 12, 2010 | Computers & Internet
My Ge Force will burn audio but not DVD.I have tried with Ashampoo,Record Now and Express Burner.The burning programme tells me there is no disc in drive
Hi Brian.
I think you are a little confused.
Your GeForce FX 5500 is a graphics card
All this does is allow you to see your desktop on a monitor and play some games.
For burning discs you need a cd/dvd burner. This is a cd/dvd drive that you can use to read and write cd's and dvd's
You say that your program is telling you that there is no disc in the drive. (Your CD/DVD burner drive)
You can burn audio discs so this tells me you know that much and you have blank cd's so my two things I need to tell you are these..
1. To make a DVD or Burn a DVD you need a BLANK DVD disc in your burning drive. Maybe you have mistakenly placed a CD in the drive instead?
2. Your Burner drive may not burn DVD's only CD's?
Check on the door to the drive that opens to allow you to place discs into it. It should say something like DVD multi recorder or Compact Disc re-writeable. If it does not say DVD on it anywhere your drive is not capable of burning DVD movies and therefore you will need to purchase another burner.
I hope this helps?
Sep 08, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
Does not recognize disk
* the disk you're inserting is not "empty" -- try it on a different computer;
* you should try a different manufacturer of "blank" disks;
* you need to upgrade the "firmware" inside your CD-writer, to recognize more brands of "blank" media;
* the CD-reader is malfunctioning -- when you "cancel" the burn-attempt, and insert a commercially-produced program CD or commercially-produced audio CD, can those disks be properly read?
* you have two CD/DVD devices in your computer, and you're inserting the "blank" disk into the "wrong" device.
Jul 18, 2010 | Yamaha CRW 2200E CD-RW Burner
My dvd drive recorder/
A common and annoying problem. This is nearly always caused by a disk that has had an attempt to be burned but did not succeed, The disk is now useless as it has had a tiny fraction of data burned on to it making now impossible to re-use.
If it is a CD/DVDRW, try erasing it first.
Mar 26, 2010 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
My combo DVD drive will burn a CD, but when I put in a blank DVD it just opens the drawer and says to insert a disc. Windows XP.
If it is in fact a Teac CD-Rewritable W58E CD-RW Burner, this will only burn CDs and not DVDs. If you put in a blank DVD you will get this error. You will need a burner that has DVD burning support.
Jan 14, 2010 | Teac CD-Rewritable W58E CD-RW Burner
CD/DVD will not burn DVD
Did you tell CDBurnerXP that you want to burn a CD? or to burn a DVD?
Does this happen with _EVERY_ "blank" disk that you insert, or just one disk?
Can your DVD-RW _read_ a previously-recorded CD? DVD?
If not, then that hardware is suspect.
Sep 14, 2009 | QPS Que! CD-Rewriter CD-RW Burner
I have a gateway pc with a DVD burner but when I try to burn a DVD, it tell me to insert blank media. When I place a blank DVD into burner it still does not burn. What is the problem?
When you put in a DVD, go to explorer and right click on the CD/DVD drive letter (usually it is E:) and click on Properties.
If it shows that the disk is 100% full, then you are using the wrong type of DVDs. Your drive may only be able to read either DVD+ or DVD-.
Aug 05, 2009 | Computers & Internet
Keeps burning a blank disk
lol the software you are using doesn't burn disk images, what you need is Alcohol 120 or PowerISO these softwares burn disk images
kind regards and please don't forget to rate us
Dec 11, 2008 | Computers & Internet
Won't burn DVD's after reinstalling Windows
Did you install the right drivers for the drive? It happened to me in the past where my DVD burner would only burns regular CDR's.
Jan 05, 2008 | Mitsumi DW 7801 TE (DW7081TE) DVD+RW...
Dell Dimension 5100 (D51L1) PC Desktop Logo
130 people viewed this question
Alun Cox
