Question about Siemens (120-5830-001) Modem
Siemens gigaset se587 wlan dsl
i have problems installing the gigaset se587. i connected the device as follows:
the yellow cable (lan) from the modem se587 to the back on my computer.
the grey cable (adsl) from the modem se587 into the splitter (filter).
the telephone line (which was initially connection from the computer to the telephone wall jack) from my computer into the splitter (filter).
splitter (filter) connected into the wall jack (telephone jack).
power line connected.
now the following lights are on
power on
lan 1 on
adsl flashing (indication that it is synchronising with the computer but not getting a firm light even not after 5 hours).
thanks for helping.
annette
  • Anonymous Feb 17, 2009
    I was using this router and everything was fine. Yesterday I woke up and it wouldn't work. Resetting didnt work. I called Tiscali and they told me that Internet is in the house so I need to reconfigure the router and/or my laptop (working on Vista). All the router lights are bright green apart from the ONLINE light. What should I do now? I've lost the CD with instructions but I'm still able to log into the router.
    Problem Solver:
  • 5 Answers
Connection should be as follows..........
comp>>eth cable>>>modem or router>>>>>fone cable>>>filter>>>>wall socket
telefone cble>> ^
no ext should be there ....... no external device should be connected........
if using any device in any socket at home then make sure that they r filterd correctly .....
try resetting the modem/router..... then check the lights.......
last option is to unplug n re plug all the cables.....
80% this should wrk....
ny more q: mail me--dashvrista@gmail.com
Posted on Sep 25, 2008
  • 6 Answers
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Posted on Sep 19, 2008
I have just bought a wireless enabled Laptop and already have two desktops in network using Tiscali through siemens gigaset se587 wlan dsl. Is this a wireless router and will I be able to connect my laptop...
yeas you should be able to as long as you know the passkey to connect to the router. windows should detect the wireless netowork automaticlty and you just select to connect
Feb 02, 2010 | Computers & Internet
Wiress LAN not connecting with Gigaset SE587 WLAN dsl
The problem may lie in one of the following: 1.) Input the right password. For example, if the Wlan router is using WEP or WPA, input the right password in the connecting device. 2.) Be sure that the WLAN router and the connecting device to use the same frequency, whether it is using 802.11a/b/g/n. 3.) Check the Router if it is supplying IP address and if it is sufficient.
May 02, 2009 | i-mate JasJam Smartphone
Short operating range of wireless router
Hello Peter. I think you may have pinned down the problem within your post. British brick walls can be very solid - and thick - which may well be enough to degrade or block your wireless signal.
The first thing I would try is to move the router to as open and central a position as you can, and see if that helps. Adding a wireless LAN antenna to your router can also help boost a weak signal a little (these just replace an existing antenna on the router).
However, other options you may want to investigate include:
1) using a wireless repeater to boost the signal from your router;
2) a powerline networking system, such as Homeplug ;
3) installing a new router with a more powerful range
..or indeed, abandoning wireless altogether and using a wired connection!
I hope this helps you explore some options, and find a solution.
Nov 15, 2008 | Computers & Internet
Siemens Gigaset SE587 WLAN dsl - Firewall
It does have a firewall but I have no idea how effective it is.
Sep 21, 2008 | Computers & Internet
I just recieved my Siemens Gigaset SE587 WLAN dsl router and i set it up but the only light coming on is the power light,is the router faulty or damaged?
Are all the cables connected correctly?
Are the DSL settings in?
If it's only the power light, and no WLAN, LAN, DSL or Internet lights on, it sounds like it may be faulty. Is it brand new or second hand?
Aug 22, 2008 | Siemens Computers & Internet
Tiscali Siemens SE587 router
I have solved my problem, after researching various messageboards yesterday to try and discover why my Siemens Tiscali router didn't work. I'm going to send it back and go with another company!
It seems there has been a lot of debate on these messageboards about Tiscali and/or Siemens products and it now seems also that no one would recommend them. I hereby add my name to that list.
Aug 19, 2008 | Computers & Internet
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Wireless internet
The other unit needs a wireless adapter to talk to the router wirelessly
make sure that the wireless function is turned on in the router software ,
you need to enter an IP address in the internet explorer to get into the router, (this should be in the manual or printed on the base of the unit).
you will need to enter a user name and password, (read the manual for these), sometimes, admin admin ,or admin password)
if you used a security key, make sure it is in the wireless software, of the wireless pc/laptop
good luck
Terry
Mar 25, 2008 | Computers & Internet
Siemens (120-5830-001) Modem Logo
2,656 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
