Question about Cell Phones
My select button not working rest buttons ok - Cell Phones
  • 1 more comment
  • rweston267 Jan 25, 2009
    i have the same problem the select dont flippin work!!!
  • Anonymous Mar 27, 2009
    My okay button isnt working!
  • Anonymous Apr 19, 2009
    I have the same problem.. my sister did too. She went to the verizon service center and got a new one because it is covered under warranty,
My select button is not working
Posted on Sep 18, 2010
2 Suggested Answers
  • 7 Answers
SOURCE: Menu Button not working
If your phone is heavily used it could just be a coincidence that you went into bluetooth and the buttons stopped working. If you have had the phone for sometime it could be the case that the keypad is worn out. this was a know problem with the K750 about 3 years ago.My advice would be to upgrade to teh C902.
Posted on Nov 02, 2008
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
I want to rest to factory settings
Welcome to Fixya. Most Canon powershot from A series up to the professional G series models have the same menu steps in factory resiting. Just follow the steps below:
1. Press the "Menu" button.
2. Press the right arrow once to highlight the "Setup" menu.
3. Press the down arrow five times to select "Reset All".
4. press the "Set" button.
5. Press the right arrow button once to select "OK"
6. Press "Set"
Please let me know if you have any questions.
Thank you for using Fixya,
seancarlisle
Apr 27, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
HOW DO I REST THE BULB LIFE ON MY Panasonic PT-AX200U
1. Press the MENU button to display the menu.
2. Select the OPTION menu and press the ENTER button.
3. Select LAMP RUNTIME.
4. Press and hold the ENTER button for approximately 3 seconds.
5. The confirmation screen will be displayed and select OK.
6. Press the POWER button to turn off projector for resetting the duration of the LAMP RUNTIME.
7. Confirm the duration of time in LAMP RUNTIME is reset to “0 H”.
Aug 05, 2010 | Panasonic PT-AX200U Projector
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Jul 06, 2010 | Xerox Phaser 6130 Laser Printer
Message on printer "Waste Ink near full"............. Where is the waste ink tank?
Right under the resting place of the cassettes. However just emptying will not fix it you need to find the reset software for your model
It covers the whole of the bottom. Remove it carefully noting how it fitted. Make a solution of teaspoon of bleach to 1 cup water dunk in a few times to remove ink. Pat dry and finish carefully with a hair dryer on medium. Then replace and follow these instructions
Canon MP780 Waste Ink FULL Reset (Should work with MP700/730/750)
This reset should be used once waste ink counter reaches full and lock-out occurs.
- To select something... Use the '-' and '+' buttons and then the "OK" button.
- To go back... Use the "Stop/Reset" button
- To reset... Use the "On/Off" button (only after you've gone back as far as possible it seems)
  1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
  2. Select "TEST MODE"
  3. Select "[8] ETC.."
  4. Select "[4] EEPROM CLEAR"
  5. Select "[1] INK COUNT"
  6. Press the [OK] button.
  7. Press the [Stop/Reset] button (Exits Service Mode)
  8. press the [ON/OFF] button (which resets the printer)
Reboot and enjoy
please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
Apr 07, 2009 | Universal Remote Control Remote Control
How do i turn off my lock on my tv
Hello there. This is taken rigth from the manual...
To reset to the default factory settings, follow these steps.
1. Press the MENU button on the remote control to
open the OSD.
2. Press the Navigation (UP/DOWN) buttons to
select the Options menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to
select Factory Preset.
5. Press OK.
6. Press EXIT to close the OSD.
You can find the rest of the manual here.
Dec 03, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Tcpip is disable on a xerox 8550 printer. How to enable it manually
Here are the steps to set up a static IP on your printer.
  1. With the printer displaying 'Ready to Print', press the [Up] or [Down] arrow button on the Control Panel and select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Connection Setup], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Network Setup], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [TCP/IP Setup], and then press the [OK] button.
  5. If necessary, press the [Up] or [Down] arrow button to select [TCP/IP], and then press the [OK] button to select [On].
  6. If necessary, press the [Up] or [Down] arrow button to select [DHCP/BOOTP], and then press the [OK] button to select [Off].
  7. Press the [Up] or [Down] arrow button to select [TCP/IP Address], and then press the [OK] button.
  8. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the address.
  9. Press the [OK] button to accept and move to the next three digits. Repeat until the required IP Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  10. Press the [Up] or [Down] arrow to select [TCP/IP Network], and then press the [OK] button.
  11. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the network mask.
  12. Press the [OK] button to accept and move to the next three digits. Repeat until the required Network Mask is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  13. Press the [Up] or [Down] arrow to select [TCP/IP Gateway], and then press the [OK] button.
  14. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the Gateway Address.
  15. Press the [OK] button to accept and move to the next three digits. Repeat until the required Gateway Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
  16. Press the [Up] or [Down] arrow to select [Exit], and then press the [OK] button.
May 20, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser 8500 not printing black
Here are the directions to enable and disable Jet Substitution. This may very well help.
Some of the print head jets will not unclog for you. If that does not work then most likely the print head needs to be replaced.
o enable the Jet Substitution mode:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. If necessary, select [Print Light Stripes Test] to make a Light Stripes Test print that shows any weak or missing jet and its jet number.
  5. Press the [Up] or [Down] arrow button to select [Jet Substitution Mode], and then press the [OK] button.
  6. Press the [Up] or [Down] arrow button to select the color for the weak or missing jet, and then press the [OK] button to select the color.
  7. Press the [Up] or [Down] arrow button to select the number of the weak or missing jet (1 to 309), and then press the [OK] button to confirm the selection.
    NOTE: If necessary, press the [Up] or [Down] arrow button to select [Save Change and Select Another Jet] to substitute more jets.
  8. Press the [Up] or [Down] arrow button to select [Save Change and Exit] and then press the [OK] button to complete the procedure.
To disable the Jet Substitution mode:
  4. Press the [Up] or [Down] arrow button to select [Jet Substitution Mode], and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select [Turn Jet Substitution Mode Off], and then press the [OK] button.
Feb 16, 2008 | Xerox Phaser 8500/DN Printer
Motorola h500
This works. Once your phone IDs the headset hit the OK button (not select) and the rest is simple.
Mar 04, 2007 | Motorola Mobility H500 Wireless Headset
Cell Phones Logo
430 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
