Question about Hitachi CM811 Plus 21 in. CRT Monitor
How to adjust color settings - Hitachi CM811 Plus 21 in. CRT Monitor
    New Friend:
Not helpful on a simple question. It's sad they make something which should be simple such a difficult task.
Posted on Sep 16, 2015
    Novelist:
  • 196 Answers
Right click anywhere in the desktop to get the right-click menue. Go to "Properties" and then to "settings". There you would be able to adjust the colors.
Posted on Jan 30, 2006
Fault/error a fault has occured switch off the machine . ensure that the screen desappears before swithing it on. it the problem persists,call for service. 124-315
Solution : Perform an Automatic Gradation Adjustment (Color Calibration) Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
  • Copy Density = Normal or Auto
  • Color Shift =Normal
  • Saturation = Normal
  • Color Balance = 0
  • Sharpness = 0
  1. Press the [Access] button (key symbol) on the Control Panel. The Access button is located above the number "3" on the numeric keypad.
  2. Using the numeric keypad, enter your administrator password and select [Confirm] on the Touch Screen. The System Administration Menu screen will be displayed.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Common Settings].
  6. Select [Image Quality]. The Image Quality Adjustment screen displays.
  7. Select [Automatic Gradation Adjustment].
  8. Load 8.5 x 11 inch (216 mm x 279 mm) or A4 (210 mm x 297 mm / 8.3 x 11.7 inch) paper in Tray 5 (Bypass Tray). Adjust the paper tray edge guide so that the guide gently touches the edge of the paper stack.
  9. Select the desired gradation adjustment screen.
  10. Press [Start]. The Adjustment Chart is output.
    NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
  11. Place the Adjustment Chart face-down on the Document Glass with both the Magenta color patches against the left side of the glass.
  12. Place 5 sheets of white paper on top of the Adjustment Chart and close the Document Glass Cover.
  13. Press [Start].
  14. To continue Automatic Gradation Adjustment with other screens, repeat steps 6 to 10. When you are finished, select [Close] until the System Settings screen is displayed.
  15. Select [Exit] to exit the System Settings mode.
Hope it helps!
May 02, 2011 | Xerox CopyCentre C128 Copier
Cyan and majenta tone is not good
  • Color Balance = 0
  • Sharpness = 0
  13. Press [Start].
Hope it helps!
May 01, 2011 | Xerox WorkCentre M-24 Color Copier
How to adjust picture color
To adjust color first of all set contrast and color controls to minimum,adjust the brightness to see clear picture than add contrast to get perfect black and white picture than add color to it for a good quality color picture.
Jan 22, 2011 | Symphonic ST419E TV
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
Problem black and white how to adjust the color.
First check whether you have set to the correct standard NTSC, PAL etc.
If confusing set it to AUTO. All you can try in the menu mode. Try adjusting color if the color adjustment is set low. Try different channel. Try DVD .
If the color still not there, it is a problem from the chromo control circuit.
Sep 24, 2010 | Televison & Video
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Faces too pink in my ip6700D
Solution: Manually adjust color from the driver (Windows)
Manual Color Adjustment Follow the steps below to make fine adjustments to the color hue for the printed output. These settings will only make minor color adjustments. If more drastic color adjustment is necessary, use an image editing application.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes', Windows Vista Click / Select Start from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.).
    Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, select 'Manual' for 'Color Adjustment.'
  4. On the Manual Color Adjustment screen, adjust each color individually to achieve the desired effect.
    Note: This screen may vary depending on model.
Dec 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Color Problem
set the temp at medium but the best is to set it at the factory setting it will last longer that way you can over heat it you are adjusting tempature to adjust color.
Nov 23, 2007 | Polaroid FLM-3225 32 in. LCD Television
Color printing
Nov 16, 2007 | Canon Pixma iP6000D InkJet Photo Printer
LCD brightness question
You can adjust the brightness or color of the LCD display as needed. 1. Set the POWER switch to CAMERA position. (In the PLAYER mode, you may only setup the LCD while the tape is playing.) 2. Open the LCD screen, and the LCD switches on. 3. Press the MENU button. 4. Turn the MENU DIAL so that VIEWER is highlighted and then press the ENTER button. 5. Turn the MENU DIAL so that LCD ADJUST is highlighted. 6. Press the ENTER button to enter the sub-menu. 7. Turn the MENU DIAL so that it highlights the menu item you want to adjust (BRIGHT SELECT, BRIGHT ADJUST, COLOR ADJUST). 8. Press the ENTER button again. You may select NORMAL or SUPER in the BRIGHT SELECT feature and press the ENTER button to save the setting. Use the MENU DIAL to adjust the value of BRIGHT ADJUST and COLOR ADJUST. You can set values for BRIGHT ADJUST between 00 ~ 35 and COLOR ADJUST between 00 ~ 35. 9. Press the MENU button to finish the setting.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Hitachi CM811 Plus 21 in. CRT Monitor Logo
880 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
