Question about NEC (SPPL1065) Projector Lamp for MT830, MT1030, GT2000, GT2000
Nec gt2000 screen color is mostly green.
Ignore the above solution. Your red polarizer or color filter is damaged. It is costly to repair this. But you will find this piece near the LCD optics. It pulls out from a tab.
Posted on Nov 23, 2007
    Novelist:
  • 196 Answers
The problem you have lies either in the CRT or the CRT card. If you are familiar with the term Video B+, check this voltage at the collectors of each of the output transistors on the CRT card. You should read about 175 volts or so at each collector. You will probably find that the voltage on the collector for the GREEN output transistor is low. If so, pull the CRT card off the CRT (with the set off to prevent any arcing) and double check that collector voltage again. If it is back to normal, then you can suspect that there is a short of some kind with the GREEN gun in the CRT.
Posted on Jan 30, 2006
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
Can't red and green colors
This usually means the red or green or both primary color module is bad. Monitors come with 3 primary color module controllers and they use them in various combinations to make the other colors. The primary colors are blue, green, and red.
Sep 17, 2010 | NEC AccuSync 900 19" CRT Monitor
Red colour does not appear on screen.
It sounds like you have a bad VGA cable. Check for a bent or broken pin in the cable. These often show up as a loss of one particular color: red, green, or blue.
Sep 10, 2010 | NEC (MTLAMP820/1020) Projector Lamp for...
HI, I have a NEC monitor 1760nx, dark blotches on the screen
Listen, for what it is going to cost you to fix the unit, you are better off replacing it and having a new warranty to boot. Simply not cost effective to repair given the cost of a new monitor these days.
Mar 12, 2017 | NEC 1760NX-1 (White) 17 in. Flat Panel LCD...
My NEC mt1075 projector is projecting a shade of blue all over. The entire screen is showing the correct image, but also with a shade of blue. I think something is wrong with the internal wiring. Is this a...
If you're using component video (red/green/blue rca cables) one of the colors may be disconnected, or the wires may be swapped into the wrong color input. If you are using a 15 pin VGA connector, one of the pins may not be getting good contact at the source or at the projector. Or if the VGA cable is split into 5-wire to make a long cable run, one of the five wires may be disconnected. Any of these problems will cause a global color shift while not affecting the color of the projector's on screen menus.
Jun 22, 2009 | NEC MT1075 Multimedia Projector
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
NEC MobilePro 900 lines in display
The problem is most likely the LCD is dying
May 30, 2007 | NEC MobilePro 900 Handheld
NEC LCD1980SX - displaying colored blocks not synchro
Have tried NEC technical Support? This looks like a circuit boatd problem
May 31, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
NEC (SPPL1065) Projector Lamp for MT830, MT1030, GT2000, GT2000 Logo
318 people viewed this question
Top NEC Office Equipment & Supplies Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
