Question about Kenmore Elite 45986 Front Load Washer
Reversing the Door
Is it possible to reverse the side the door opens on for the Washing Machine.
    Genius:
  • 1,028 Answers
Nope only the dryer doors are reversable..last washer to have reverable door that i know of was old neptune
Posted on Sep 08, 2008
How is the doors reversed on ffp187b
Reversing your washer door - YouTube
? 5:14
www.youtube.com/watch?v=abpAu_5Uhfc
Feb 16, 2011 - Uploaded by Kenmore You can switch the side the door on our new dryers (model #s starting with 417) swings on. This video will tell ...
Jul 30, 2015 | Washing Machines
Reversing door
some can be many can't use your head and look at the hinges
May 11, 2015 | Freezers
Garage door opener keeps reversing as I try to close my door
Mine do that. The sensors located at the bottom on either side of the door have to "see" each other. It is very easy to bump them out of alignment. Check that first. It is possible that they are faulty, and replacements cost about $30. You can't, and shouldn't bypass these for safety reasons.
Dec 09, 2013 | managemylife.com
Reversing door position Samsung washing machine
talk with the local samsung authosized repair agent and ask them if it can be done
May 18, 2017 | Samsung Washing Machines
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Reversing sensor blinking
Tweak the sensors to see if you can stop the blinking. They must be pointed at one another and not blinking for them to work properly.
Dec 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reversing doors on Roper Refrigerator
If the door is reversible you will see plugs on the opposite side and top . pull out the plugs and save . remove handles and hinges and move use plugs on other side
Aug 07, 2009 | Refrigerators
The door reverses back to open position instead of closing
SOUNDS LIKE A SENSITIVITY ISSUE UNHOOK THE DOOR AND TRY IT MANUALLY TO BE SURE IT DOESN'T BIND OR IS TOO HARD TO OPEN OR CLOSE.
IF ALL IS WELL CHECK THE SENSITIVITY SETTINGS ON THE BACK OR SIDE OF THE OPENER.
YOU WANT THIS SET AS LOW AS POSSIBLE AND STILL OPERATE THE DOOR WITHOUT REVERSING.
NOTE: THE FULL RANGE OF ADJUSTMENT IS ONLY ABOUT 3/4 TURN SO MAKE A VERY SLIGHT ADJUSTMENT AND THEN TRY IT AGAIN.
HOPE THIS HELPS
Feb 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Mar 29, 2008 | Whirlpool AWM5125/1 Front Load Washer
Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Kenmore Elite 45986 Front Load Washer Logo
468 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
