HEC-250BR SCHEMATIC
I WANT TO USE THIS POWER SUPPLY TO OPERATE SOME SMALLCNC EQUIP. I NEED TO KNOW WHICH LEADS SWITCH THE POWER ON. A PIN OUT DIAGRAM WOULD BE HELPFUL.
THANKS,
GREG
  • 5,568 Answers
This page seems to contain all the info you need but it is unusual that the supply does not have a chart defining lead colors and output capabilities.
http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
Posted on Sep 19, 2008
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
I have an Antec Truepower 2.0 TPII-430. This power supply provides power to the fans but when I push the computer power-up button, nothing happens. I installed another similar power supply and everything...
Test it. Unplug the molex connector from the mothrboard. You can use a wire or a paper clip to test it to power on. You will connect (short) pin 14 to and ground pin. (diagram here) For example, put one end of the paper clip into pin 14, and the other end into 13, 15, or 16. If the power supply turns on and fan running then maybe a problem with the front panel switch on the computer case.
P.S. make sure you unplug all other leads to drives before doing this.
Apr 06, 2011 | Antec : True430 430W P4 ATX Power Supply...
How to make regulated power supply
The easiest way to do this is to use a 3 pin regulator IC.
For a 5 volt supply go to this WEB site,
http://schematicwiring.com/simple-electronic-applications/5v-dc-regulator-with-3-pin-regulator-circuit-schematic-diagram/
For a variable voltage power supply go to this WEB site.
http://www.engineeringslash.com/power-supply/three-terminal-adjustable-regulator.html
Mar 16, 2011 | Computers & Internet
I too have a similar problem. The LED on the motherboard is on when power is applied. I think I've isolated it to the front chassis power and reset switch combination. The reset switch crumbled when I...
Both the reset and power switches are normally-open, momentary contact to operate. If you twist the reset leads together, it's the same as permanently holding the motherboard reset button pressed. You don't need the reset button in any case, so you don't have to worry about replacing the switch.
The LED on the motherboard indicates the presence of standby voltage, so the power supply is working to at least that degree. The power switch is only a signal to the motherboard to turn on the power supply and start the rest of the system operating. So if the system doesn't come on when you press the power switch, either the power supply is bad or something is preventing the motherboard from starting properly.
A quick test of the power supply is to ground the PS_ON pin in the output connector:
Unplug the connector from the motherboard and use a piece of wire or a bent paperclip to short the pin marked PS_ON to the ground pin on either side in the same row (not across to the other row, which is the standby 5-volt pin!). If the power supply is working, it will turn on and its fan will start running. This doesn't mean the supply is 100% good, but if it doesn't start with this test you certainly need to replace it.
If the supply starts this way but not when it's connected to the motherboard and you press the power switch, then you'll need to figure out why the motherboard's not starting. There may be something wrong with the board itself, or something connected to it is preventing it from starting. Removing parts and parts substitution will help you find the culprit.
As far as getting a replacement switch assembly, you might try Gateway support to find the assembly part number and see if they offer it for sale, or check eBay. Or you can try replacing the switch by itself. On some assemblies the switch is just held into the bracket by tabs, and companies like Digi-Key and MCM sell suitable replacements.
Jan 18, 2011 | Gateway 510 X (10272197) PC Desktop
Voltage regulator
One of the most common type is the 3 pin - 1 amp voltage regulators in a TO-220 package, they are the 78xx positive regulators and the 79xx negative regulators. The xx denoted the voltage output of the regulator.
I don't know what type of regulator is used in the APN 6003, if you can obtain a circuit diagram it might help you.
Sep 27, 2009 | Motorola Computers & Internet
Boss psa 120s automatically shuts down and does not turn on
I'm going through here just to share the circuit diagram (schematic) for Boss PSA adapter because I know that many people need to repair their damaged fonts but can not get the original wiring diagram.
Savio
Jul 08, 2009 | Boss PSA-120 (761294015735) Power Supply
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
Need physical dimensions of HEC HP585D 585W ORION HP585D ATX
No, given your old PSU's dimensions the HEC PSU would be too large. It sounds like you have a micro-ATX case.
Apr 06, 2009 | HP HEC HP585D 585W ORION HP585D ATX 12V...
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
722 people viewed this question
David Payne
David Payne
