Question about HP OfficeJet 6210 All-In-One InkJet Printer
Carriage jam Printer is now about 2 years old and performed well thus far.  however recently it has started making a noise and printing skew after 2 or 3 pages.  it starts a banging noise as the paper goes getting faster and faster and eventually it comes to a grinding halt with a very messy printout.  i have tried all of the usual tricks - on / off - opening it up and checking for any obvious mechanical   problems - never anything obvious.  usually after a 'rest'  and  restart it will print 1 page normally and then revert back to its old tricks again on the 2nd page.  is it telling me to replace it - or is this fixable.  thanks any advice appreciated - including what would be the most appropriate replacement if it came that.  thanks Ross M
  • 2,071 Answers
Posted on Sep 07, 2008
Paper jam cleared but wont start
  1. Unplug the power cable.
  2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step five . Do not try to force it to move if it is hung up on something. NOTE: Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
    • If the carriage moves freely, skip to Step five .
    • If the carriage does not move, continue with the next step below.
  3. Remove the print cartridges.
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Remove the rear access door.
  7. With your fingers, rotate the rollers "up" three full rotations.
  8. Push the rear access door back into the printer until it snaps firmly into place.
  9. Replace the print cartridges.
  10. Plug the power cable into the HP All-in-One.
  11. Turn the power on.
Step five: Reload and test the printer Once the jammed paper is removed, verify that the printer is still functioning properly.
  1. Reload the printer with plain paper.
  2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
Step six: Service the printer Perform all the steps mentioned above. If problem persists, service the printer.
Oct 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HP Pro 8500 printer has carriage jam. I have opened every door and there is no paper jam.
Sometimes the paper gets caught inside the printer all the way to the right (or left) of the print carriage. You will miss seeing it because the print carriage has moved the jamed paper to the right (or left) out of view. Carefully and manually move the print carriage to the opposite side and you might find small pieces of jammed paper there.
Jul 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP 1720 I making a noise when printing.
    NOTE: Refer to the Testing section in this document for instructions on performing the tests.
  1. Turn the printer off, and then turn the printer on. The grinding or squeaking noise should not occur while the printer is initializing.
  2. Perform a paper path test. The grinding or squeaking noise should not occur because the carriage should not be moving.
  3. Perform a self-test to localize the noise.
  4. Check the printer for obstructions by lifting the top cover and making sure nothing is blocking the carriage movement.
  5. Check the paper path by following the instructions below:
    1. Remove all media from Trays 1, 2, and 3.
    2. Pull out any visible stuck paper.
    3. Lift the top cover, and pull out any jammed paper.
    4. If you are unable to free the jammed paper, pull out the handle of the paper knob, pull the knob away from the printer, and rotate it to remove the paper.
    5. Lower the rear access door by lifting up on the two rear door latches.
    6. Remove the back panel by pushing the two catches inward.
    7. Pull out any paper that may be stuck inside.
  6. Wipe down the milky white strip (see Figure 1) that the front of the carriage glides on with a clean, soft, dry, lint-free cloth.
Figure 1: Location of the white strip
bpp90119-1.gif Replace the whole unitgtabtop.gifIf the printer is still making a grinding or squeaking noise after following the steps above, replace the whole unit. See Whole Unit Replacement instructions, which are included with the whole unit replacement.
Testinggtabtop.gifUpon replacement of the whole unit, perform a Paper Path test and a self-test as described below to verify that the new unit is functional.
    Performing a paper path test
    1. Press the MENU button on the printer control panel until Diagnostics Menu is selected.
    2. Press ITEM until Perform Tray x Paper Path Test is selected.
    3. Press SELECT to perform the test.
    NOTE: The paper path test will terminate only when the paper in the tray being tested runs out or the printer is turned off.
    Performing the stand-alone self-test
    1. Press the MENU button on the printer control panel until Self Test Menu is selected.
    2. Press ITEM until Print Menu Map is selected.
    3. Press SELECT to perform the stand-alone self-test.
Hope this help. Please Rate My Response! Thanks!
Mar 31, 2009 | Dell 1720dn Laser Printer
Photosmart 8750 carriage jammed error and skewed printing
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
Thanks for using FixYa.
Jan 09, 2009 | HP Photosmart 8750 InkJet Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
My printer will not load and the window says the carriage is jammed. It is an HP Officejet 7410 All-in- one. It first had the message Paper jam and after I opened it and there was no paper jam I...
1. Check if there are broken parts inside the printer-carriage area
2. Turn the printer on and off
3. Clear any paper jam by opening the rear access door at the back of the printer. If there are no paper jams. Clean the rubber rollers with a lint free cloth that is moist with water
4. Make sure that the carriage can move freely
5. Remove then reinstall the ink cartridges
6. Make sure that the control-panel faceplate is correctly installed
7. Plug the printer directly to the wall outlet
8. Perform a partial reset on the printer.
a. Unplug the power cord from the All in One
b. Press and hold # and 3 while plugging the power cord
c. Do not release the two buttons unless the printer would say reset
9. Try to print
10. If this would not resolve your issue then the printer sensor is already defective.
Aug 06, 2008 | HP Office Equipment & Supplies
CANON ip 4300 - 5100 error & prints skew onto DVD
I had this eror. It was caused by indexing error left to right.Would print some then cancel after starting to make clunking and left to right error gets to large.(white edge up the side of full page print).
There is a toothed print head carriage drive belt and a clear indexing strip above the heavily white greased bar behind print head carriage.
If this clear indexing strip gets grease or anything else on it the print head cannot index.
With print head at full right position,power off, I carefully wiped the clear strip by pinching between clean dry fingers and wiping up and down the strip a few times,maybe use cotton wool buds and IPA or methalated spirit if you can't get your fingers in there without breaking the strip. then with power on print head in change cartridge position,push carriage to far left and wipe right side of clear strip.I pushed carriage full left to right a few times,Then ran print head alignment.Fixed without taking apart.
Jun 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
