Question about Acer Computers & Internet
How can I identify what printer is compatible to my computer - acerm1610
  • 105 Answers
Ask at your nearest computer store to be sure but most printers are compatible. if you get a used one and it doesn't have install disk you can download from the internet. i prefer lexmark. i use it on acer, hp, home built. no problems on any.
Posted on Sep 13, 2008
Am getting error-toner cartridge is not compatible check users guide.even if i put a new toner
Cannot guess the reason unless you identify the brand / make / model of your printer.
Most new toners have an embedded chip to recognize if they are genuine to prevent refill of toner
Jun 08, 2016 | Office Equipment & Supplies
Windows say asuio drivers not installed. need to identify audio card and driver and download and install the driver
try to check your system manufacturer to identify what audio drivers needs to be installed. It needs to be compatible with your motherboard and the chipset of your computer.
May 30, 2011 | Computers & Internet
Can I get windows 7 drivers for my DPP FP30? Just changed to W7 and it looks like my precious printer won't work any more!!
Install the drivers in XP or Vista compatibility mode.
Insert the setup disk in your CD/DVD drive. Choose to view the files in Explorer.
Scroll down to the file "Setup," which is identified as an application.
Right-click the file and select "Properties." Click the "Compatibility" tab at the top of the resulting window.
Check off "Run this program in compatibility mode for:" and choose "Windows Vista" or "Windows XP Service Pack 3" from the pop-up menu.
ALSO check "Run this program as administrator" at the bottom of the window.
Press "Apply," then "OK."
Now you can double-click the "Setup" file and run the software installer.
Mar 12, 2011 | Sony DPP-FP30 Thermal Photo Printer
The printer is used to print a Bill of Lading on a multipart form. It prints the entire BOL fine except for 1 field on the top/ right side that the invoice number prints in. It will print real small 1...
I would suspect the problem with the field at the top right of the page is being printed incorrectly because the printer receiving an escape command (control code) the printer either does not recognize or performs a wrong function on the 2280+.
If the printer was printing correctly and has suddenly started printing incorrectly it may be best to investigate what has changed ie have any of the following changed;
  • Printer driver or setup on the host computer system
  • Connectivity method
  • Printer settings may have been changed (check the emulation setting)
If the printer is a new setup and has not yet printed this document correctly it may be worth doing the follwing;
  1. If the printer is connected via the parallel interface (either directly to a computer system or via an external print server ) disable Cx-Bid
  2. If you know which driver or type of escape commands are used on the computer system ensure the emulation setting on the printer matches the host system.
  3. If you are not sure of the system setup perhaps try setting IBM for the emulation setting.
  4. If the above actions do not rectify the problem and you are able to select drivers etc on the host system ensure the 2280+ driver (or a compatible Epson or IBM driver is used ie either Epson LQ2550 or IBM ProPrinter XL24)
Further to this it may be nessesary to investigate the data file being recived by the pritner, by performing a hexdump to identify the cause of the problem and also identify a suitable soluion.
Mar 11, 2011 | TallyGenicom 2280 Matrix Printer
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
I recently bought a new hard drive to update the "tired out" model in my gateway model gt5674. i was told that i needed a SAS compatable motherboard to get this new hard drive installed. is there any...
Take the disk-drive back to the computer-store,
along with your computer, and exchange the new disk-drive for one that is compatible with your computer. Within 15 seconds of viewing the "inside" of your Gateway, they should be able to identify the correct model of disk-drive that will be compatible with your current motherboard.
Or, the more-expensive option: buy a PCI add-in card to add a 'SAS-compatible' interface (although I've never heard of such an interface!!!!) to your computer.
Jan 15, 2010 | Office Equipment & Supplies
How to identify this scanner on my computer ??
unless you have the i-send option you will need network scangear loaded onto your pc this is free to download from the canon web site www.canon.co.uk
Dec 14, 2009 | Canon imageRUNNER 2870 Copier
Attemping to install software that came with the printr and computer wont see printer ... I have recently received a new computer at home and am just now attemping to install printer onto computer screen....
Need to know a bit more. Is this an older printer? It may not be compatible with your computer/OS. Try checking with your Operating System to see if it is compatible with the printer. Go to Windows Help to find out more about printer conflicts and compatibilities.
Nov 21, 2009 | Lexmark X7350 All-In-One Printer
I am trying to install Lexmark Z600 series color jetprinter with disk provided but wont install
Ok first make sure its compatible with your windows for the first time that you install the printer with the computer ,the computer recognize the printer but if the computer dont recognize the printer its because its not compatible that happened to me and i went back to the store and exchange for a HP printer compatible with Windows Vista I hope this help Good Luck
Jul 07, 2009 | Lexmark Z600 InkJet Printer
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
