Question about Hotpoint WMA46 Front Load Washer
WMA46 Door Seal
How do I change the door seal.
    President:
  • 1,462 Answers
Turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Posted on Sep 07, 2008
3 Suggested Answers
  • 1462 Answers
SOURCE: DOOR WILL NOT LOCK
assuming that you didfi not unwire ther door lock, the problem is probably just that the door seal just needs bedding in and you should be able to start by closing more firmly and pushing in till the door lock catches. did you properly seat the door boot on the cabinet?
Posted on Apr 07, 2007
  • 1462 Answers
SOURCE: hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
Changing a door seal how do you replace the door seal ?
  1. Check the door seal size. Measure your door or doors, and take down the make and model number. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+9665908481+9016233241+8388126455+8941458308+8509902424+8509902424+9683278076+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  2. 2Order a replacement door seal. It's easy to find them online. Make sure to check the model number for your refrigerator when you order it. When it arrives, hold the new door seal up against the old door seal to compare the size. The sizes are rarely incorrect, but it will save you the trouble of doing the job twice if you happened to receive the wrong door seal.
  3. 3Locate the screws. Lift the edges of the seal and find the screws underneath that are holding in the plastic liner and door seal. Often, the screws hold in a plastic liner, which in turn clamps the door seal to the door.
  4. 4Loosen the screws. Begin to loosen the screws that hold in the door seal. DO NOT take the screws all of the way out. It is unnecessary and will create more of a job for you. If at all possible, loosen only a few screws at a time, as you go.
  5. 5Remove the old seal. Once all of the screws are loose, the door seal should easily slide out from behind the plastic liner. Don't be too forceful when doing this step, since some plastic liners can be quite brittle and crumble if you are too rough. If the plastic is old, replace it.
  6. 6Insert the new seal. Begin slipping the small lip of the new door seal behind the plastic liner of the fridge. The best method is to start in the top corners and work your way around the door.
  7. 7Tighten the screws. Once the door seal is in a certain section, you can begin tightening the screws. Begin with the 8 corner screws, and then check the alignment of the door while closed. Also check that the seal is even and straight. If the door is twisted, you can easily manipulate the door to twist back into shape whilst the screws are loose. Then tighten the remaining screws.
  8. 8Apply powder. Use a bit of baby powder or talcum powder to prevent sticking. Rub some powder around the hinge side corners of the door seal, and where the seal slides. This will help to prevent the door seal from twisting as it meets the metal of the fridge. If this still doesn't prevent twisting, then wedge a screwdriver under the seal as you close the door and leave it shut for an hour.
  9. 9Check for gaps. Look for any gaps in the door seal, especially at the top on the opening side. These can form due to the door dropping or being out of alignment. One way to check is to turn on a flashlight and place it inside, then close the door and look for light.
  10. 10Fix any gaps in the door seal. Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
  11. 11Check the corners. If the application of powder hasn't prevented the door seal twisting, then wedge a screwdriver under the seal as you close the door and leave it shut for an hour. The door seal will then have enough time to mould into the correct shape.
Aug 29, 2010 | Refrigerators
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Hotpoint WMA46 door problem
From the symptons you describe, it could be a broken or weak spring in the door handle, which ca be fixed relatively inxpensively, that is where i would start, you can purchase one directly from hotpoint, or possibly a local repairer. if that does not cure the problem, then the odds are it will be a faulty programme module.
Hope this helps.
Jan 13, 2010 | Hotpoint WMA46 Front Load Washer
I need to change the door seal, any advice??
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 11, 2009 | Siemens WM5487A Front Load Washer
Hotpoint wma46 door lock
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
Door seal
switch off your power to the washer pull-out so you can undo the screws for the lid take the lid off now open your door there should a clamp surrounding your door seal you may not be able to see it but it is there undo it now look inside your washer to the inside at the back part of your door seal there will be a clamp this should either be a spring clamp or a screw clamp undo this clamp door seal with pull off now reverse the order of how you took your door seal out problem solved it is not too hard to do once you have done it you will find any washer door seal easy to replace trust me done thousands m8
Aug 13, 2007 | Bosch Classixx WVF 2402 Front Load...
DOOR WILL NOT LOCK
Apr 07, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
266 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
