Question about Toshiba Satellite P205-S6287 Notebook PC
Power When I check the power cord with a multi-meter it has the required 19v DC +/-1volt but plugging it into the laptop... Well it doesn't work anymore. The plug LED doesn't come on anymore and the battery doesn't charge. I'm trying to take it apart and see if there is anything wrong on the jack inside but without the manual to disassemble it's not going so well. I do this kinda work for a living too, but most of the stuff I take apart and fix is in a VME chassi. So basically, do you know where I can find a manual for what I need, and have you seen this problem before?
Its the female reciever on the laptop from moving left to right and up and down the hole you put the metal prong into is now too loss and needs to be replaced
Posted on Sep 21, 2008
The non replacable battery on my Toshiba CL 151 B1204X will not charge or operate on battery
the battery problem arise vy bad battery or incompatible battery. also there may error on charge circuit. to check pls remove the battery and plug ac adapter , close the lid and turn it , check battery outer 2 pins on the laptop by multi meter ,it have to be set up 1or 2 volt than the battery output current.
but measure DC Volt near 19V. or laptop input DC voltage pls check the battery charge circuit and repair, also pls plug the battery to another compatible laptop and check.
Sep 25, 2017 | Toshiba Computers & Internet
I bought this Thomson TV in the Netherlands and moved to the USA and now need a power cord for model nr 20LCDBO3B with serial number FRN104824 (19V DC) Thanks
I thought the power adapters were multi voltage. Have a close look as if it is a switch mode type, you may be lucky and just have to change the plug top over.
If not try ebay
Feb 12, 2011 | Thomson 20LCDB03B 20 in. Television
My laptop wont turn on, even when the power cord is plugged in. i tested the power cord with a multi meter and the cord has power
Have you tried removing your battery for a minute then plug it in again?
Check also your charger if it has a voltage output using your multi-meter. the expected voltage you will read is indicated on your chargers name tag in DC volts (observe polarity).
When you press the power button does anything happens to your laptop or nothing happens at all even indicator lights?
Don't forget to rate me...
Jan 06, 2011 | Gateway MT3705 Notebook
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
Normal 0 When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Oct 22, 2010 | Acer Aspire 5100 Notebook
My charger does not power up my Toshiba Satellite A305, is it the motherboard?
Have you tried running it without the battery?
  • If this works, then the battery has died. Replace it or run on p/s alone.
  • If not, and the power supply is definitely working, then the laptop itself needs repair.
Apr 07, 2010 | Toshiba Satellite (K000004080) Motherboard
Hi, what is the size of the nec f5275 dc jack? thank you
The DC jack for this laptop is specified as follows.
AC Input : 100~240V /50-60Hz
DC Output : 19V 3.42A
Connector size: interior diameter: 2.5mm
external diameter:5.5mm
Power Cord Required: 3 Pin ( Clover Leaf )
Nov 14, 2009 | Televison & Video
I have a gateway 3250GZ laptop, the DC in jack
double check your power cord! i just went thru 3 days of troubleshooting my Gateway M6318. Thought it was my dc jack.... after tearing down my laptop... finding the jack in tact, soldering in tact. testing my power cord... off and on for 3 days.. it was reading 19v.. which is what it should... but as of today began zero reading on tester. Tomorrow I will buy a new power cord to see if this was the correct problem... wish i would have found the above reference site before all the other troubleshooting i had done... tearing down my lap top, pulling, tugging, twisting my power cord to get a good charge.... etc. hope this helps!
Jul 12, 2009 | Gateway MX3228 Notebook
Hi i asked for my ibm t40 laptop dc jack to be replaced and i have looked in my profile but all i can see is dc jack for a printer my problem is changing the dc jack on my ibm t40 LAPTOP
Problem with power socket on the laptop, it may caused by a dry solder joint and needs to be resoldered or the power socket may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars.
If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
Jun 20, 2009 | IBM Computers & Internet
Toshiba laptop battery or AC/DC adapter
step 1.First remove the battery out
step 2.Try to plug in the AC/DC adapter and see any Power light or something on your machine. If you have power light on your machine that mean your adaptor is supplying electric.But still there're some adapter that don't really supply a good DC voltage
we need to further check.
step 3: incase no light nothing on your machine you need to use analog meter or digital meter to check that your adapter is giving out DC Volatage around 16-19V
Best of luck, takecare.
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite P205-S6287 Notebook PC Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
