Question about Intel PRO/Wireless 2200BG 802.11g/b
Wireless network found
I have Intel(R) PRO/Wireless 2200BG Network Connection card on my Dell Inspiron laptop. I checked using Device Manager that everything related to this hardware is working good and there are no faults.
I have set up a wireless network using DLink WBR-1310 wireless router and found that another laptop (HP laptop) could very well detects the signal, but my laptop can not.
Any help in this regard would be appreciated.
My email id is bhavesh.sinha@gmail.com
Thnx,
Bhavesh.
  • alibasho Jan 08, 2009
    its same here..
    I have an IBM thinkpad.. it detects another routers except mine! (the brand is called levelone wbr3600.. it's up to date) although i can surf wirelessly through my ps3.
  • 787 Answers
If it cannot find any networks, check to see if there is a wireless on/off switch on the computer - look carefully some are well hidden. The switch turns the antenna on and off but windows still detects the network adapter and thinks everything is ok.
Posted on Sep 28, 2008
My pc crashes when I start a wireless connection using the computer wireless button. Network card is Intel Pro 2200BG wireless LAN. Have reinstalled the driver with no success.
try this...
1. download the updated driver
2. go to the device manager then uninstall the wireless driver
3. restart your computer then reinstall the driver
4. restart your computer for the last time and the driver will be installed properly
Jan 14, 2011 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless connection
you can try to totally disable it, by doing right click of the mouse in top of the broadcasting wireless icon. once is disabled, you can go by START / CONNECT TO / WIRELESS CONNECTION and try again. that should work.
Apr 23, 2010 | Toshiba Satellite M45-S331 Notebook
Dell Inspiron E1505- Intel(R) PROSet/Wireless 3945BG Network. I also have Comcast Cisco modem and cisco Linksys router. I was getting an error "problem applying profile". I went to the contorl...
I had usualy solved mysterious problems with other intel PRO wireless cards not authenticating, loosing signal, etc, by simply upgrading to the latest intel drivers.
Also using the Intel connection manager instead of the windows or Dell/other notebook manfucaturer's product is far more reliable.
Hope this helps.
Feb 09, 2010 | Intel PRO/Wireless 3945ABG Network...
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
Wireless network connection, Intel (r) pro/wireless 2200bg says not connected. How do I get it to say connected? I have disabled it and then enabled it and to my surprise it still says not connected- How...
Try these first:
Make sure that the wep password is correct.
change channels to 1-6-or 11.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Feb 18, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Reboot necessary to find ISP server
2200BG is a very old Intel wireless card. Its driver had a lot of issues that were fixed over the years. Try the latest driver from Intel site: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1637&lang=eng (make sure to choose correct OS).
Jan 11, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Intel PRO/Wireless 2200BG 802.11g/b Logo
260 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
