Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer FWT449GFS1 grinding sound
The washer developed a griding sound midway thru a wash. Turning the inside steel chamber by hand you can detect a grinding sound around the half turn. The wash seems fine, but the sound of mechanical grinding is concerning.
Any ideas?
Al
    Sergeant:
  • 276 Answers
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
Posted on Nov 18, 2008
Frigidaire front loading washer model FWT449GFS1
For a repair manual, contact Frigidaire directly.
Oct 07, 2017 | Washing Machines
On my 6.3 yr old frigidaire front load washer (model GLTF1670ASO), the wash cycle does not dispense the water, but the rest of the cycle works fine. In other words, the washer tumbles dry clothes thr
sounds like the pressure switch is stuck its located inside the washer it has a small tube on it that is connected to the pressure chamber on the outer tub these block up with old soap ext and you have got to take the tube off and blow or unblock with a small wire
Nov 21, 2011 | Frigidaire GLTF1670A Front Load Washer
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Installed a new timer in my frigidaire model#fwt449gfs1 now it will not enter final spin
check the motor controller for proper operation.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Jul 30, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
378 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
