Question about Hitachi 51F59 51" HDTV Projection Television
Connect to dvd player
I can't get the t.v. to play through my surround sound, but the home theater system plays fine. how do i connect it all so that i'm in home theater mode all the time?
On the back panel of your tv you will see two audio inputs labeled AUDIO TO HI-FI. Plug your surround sound audio jacks, ( red and white ) into that. Plug your video jack ( yellow ) into what ever number input you are going to use for dvd, if needed. This will allow you to watch tv and hear it in your surround sound. You should also go to menu- then- audio option and turn off your tv internal speakers, this will allow your tv remote to control your volume of surround sound. Hope this helped.
Posted on Sep 12, 2008
HAVE A CRAIG SURROUND SOUND HOME THEATER SYSTEM WITH A DVD PLAYER HAVE GOOD SOUND BUT NO PICTURE WHEN PLAYING DVDS
Check whether you have connected your HTS video out put to TV/PROJECTOR 's Video input. Try HDMI port for better result.
Oct 31, 2013 | Craig 5.1 Surround Sound Home Theater...
I cant get the tv to go through the surround sound i can only get the surround sound to play when its a dvd playing do i need another wire to go from the dvd player or will it not work no matter what plz...
If you've got the Audio Input Source set as TV-Audio and it won't play as Surround Sound then you'll need to connect the Audio Out from your TV (if it has one?) to the Audio AUX IN on your LH-T360SE and change the Audio Input Source to AUX.
Jun 04, 2011 | LG LH-T360SE Theater System
My home theater system plays cds but will not play dvds, what can I do to fix it, makes a scratching noise when i put dvds in it, but plays fine with a cd.
There is something wrong with the DVD drive assembly inside. If you're brave, take it apart and check on what is making the noise. Also, try using a q-tip to clean the laser head if it's accessible.
If that doesn't help, it's time for a new DVD player.
This is why I always recommend people buy a home theater system without a DVD player built in. The DVD player is the weakest link, and stand alone DVD players can be purchased for as little as $25 depending on if you want upconversion or not.
If you cannot get the DVD player working in your surround system, just replace it with a stand alone DVD player, if you can, check to make sure there are audio inputs on the back of the receiver. If there are no audio inputs on the receiver, you will have to get the entire surround system replaced. If so, purchase a separate DVD player and surround system.
Jan 13, 2010 | LG LH-T754 Theater System
No sound through surround
this is because the home theater receives 5.1 channel... change it it will work...
May 17, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
I can't get my coby DVD 937 to play sound while watching tv. It works fine while playing a DVD or CD????
there should be an input line of just audio cable hookups (one red and one white) that you have to run and an output cable from your tv audio output of just red and white. make sure the tv says output or line out and the surround sound system says input or line in
May 05, 2009 | Coby DVD-937 5.1 Channel DVD...
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Audio problems with surround speaker system on
I have had the same problem on my home theater maybe you should try to wiggle the speaker cord it could be loosly hooked up to your home theater
Nov 22, 2008 | LG Televison & Video
LX3000D DVD Digital Surround System
the dvd player has a strip that comes from the lens to the board have that checked out by a yech probably it is broken or needs to be cleaned.
Mar 07, 2007 | Philips LX3000D System
DVD SUrround SOund Help
Ensure that there are no conductive material's (metallic thread, fine wire such as shielding braid)near your Aux inputs that may be shorting your connections. You could also try using an emory board or fine sand paper, or even a pot scrubber on your inputs and RCA plugs in case it's just simply dirty and hampering the connectivity.
Aug 18, 2006 | GE GTD120 System
Hitachi 51F59 51" HDTV Projection Television Logo
187 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
