Lamp timer reset
I just need to know how to reset the timer,thanks it's a ben q 6110 projector
  • 2 more comments
  • scnewhomes Feb 01, 2009
    I have a dream vision cinexone & we replaced the lamp.  I worked great so we sat down & watched TV.  We had no idea we needed to resest the timer!  Now the power & lamp light flash & there is no picture.  The manual says to follow the instructions on the screen but there is no screen!  How can i fix this?  Thank you in advance!
  • crosby4178 Mar 09, 2009
    I have the same projector, Benq PB6100 and after 2000hrs the warning started appearing. I have replaced the bulb but cannot reset the timer as the screen disappears and the temp light appears. Any help would be appreciated.
    I have already tried holding down the up button when the warning message appears but to no good effect...thanks
  • fordlj Apr 15, 2009
    I have a Sharp Notevision PG-C30XU projector. I've changed the lamp, cleaned the filter and followed the instructions to change the lamp timer. The timer will not reset. Any suggestions?
  • ilidia May 14, 2009
    I have a sony VPL-VS4 and it display Amensage to replace the lamp. It has 2046 Hs. I replace the lamp and press on the contrl panel RESET,<,>, enter and the mensage to replace the lamp dont disapear. Has it a solution?
  • 563 Answers
Hi there
Very easy - switch on your Projector ( no need for a source )
Hold in the Up arrow key on the Projector for a couple of seconds untill the on-screen message appears and just follow the on screen instructions.
Posted on Sep 26, 2008
Ok
with the vpl in standby mode use control remot and press reset, left, right,enter .
thanks
Posted on Nov 15, 2008
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
Projector turns on. The blue screen comes on. After the ben Q symbol disapears a warning measage comes up 2004 hrs, change bolb if not bright. Then picture disapears and the temp light comes on! Any...
hi,
its because ur lamps life comes on its end. its time to replace the lamp. after replacing u should rest the lamp timer to zero. if u have already replaced the lamp do the following,if not also.
1 Press and hold the Exit (up arrow) button on the projector for 5
seconds to display the total used lamp time.
2.Press Auto button the projector or on the remote control to
reset the lamp hour to "0".
3. Wait about 5 seconds to let the OSD disappear.
ok
Dec 22, 2010 | BenQ PB6110 Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
No display from projector
try resetting the lamp timer. if that doesn't work: listen for a high pitched whir when you power it on. if you don't hear it, the colorwheel needs replacing. if you do hear it and it doesn't light, the ballast is bad and needs replacing.
Aug 10, 2009 | HP Digital Projector Vp6110 Multimedia...
Sony projector - replacement lamp counter
  • Set the projector in standby mode.
  • Press the following buttons on remote control in following order for less then five seconds each...
  • RESET,
  • ENTER
Lamp timer is reset now.
This is also mentioned in user manual page 50
Thank you.
Dec 12, 2008 | Sony LMP-H130 Projector Lamp Projector...
How to reset the lamp timer on a Marantz VP8600 Projector
To reset the lamp timer for the Marant VP8600 you will need your remote.
Step 1: Make sure the PJ is powered on
Step 2: Press the leftt arrow key, then right arrow key, then the Freeze button
Step 3: Press enter to reset
Sep 26, 2008 | Marantz VP8600 DLP Projector
Sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Jul 09, 2008 | Office Equipment & Supplies
Projector
Go into the projector menu, OPTION and then select LAMP TIME.
May 30, 2008 | 3M Projector lamp Projector Lamp
Reset Lamp sequence for Sharp XGE-3500U
Hi there
I checked out the users manual and according to it you should be able to reset the unit by going into one of the Menu's subfolders.
Mar 22, 2008 | Sharp Projector lamp Projector Lamp
2,279 people viewed this question
jasbo
jasbo
