Question about Acer (9005210464), (64 MB) Graphic Card
Acer 9800 video problem
When we boot up computer pixels are messed up through out screen can read log on names but not the rest of the screen. Re did drivers once and it fixed it but then it messed up again. Reloaded operating system from a back up and it was fine til next boot up then back to pixel hell. Graphics card nvidia geforce go 7600
    Problem Solver:
  • 6 Answers
Your graphics card is defect/damaged. Send your laptop back to Acer and they will put in a new VGA card. If the problem is turning back everytime, your motherboard is probaly damaged. There is no homemade solve possible!
Hope this helped.
Posted on Oct 07, 2009
  • 22 Answers
UR GRAPHICS CARD IS DAMAGED IF POSSIBLE TRY INSTALL THE CARD IN ANYBODY ELSE COMPUTER IF THE PROBLEM IS STILL THERE THEN UR GPU IS 100%DAMAGED.I DONOT WHAT MOTHERBOARD U R USING BUT WHATEVER MOTHERBOARD IT IS EVERY MOTHERBOARD HAS A ON BOARD VIDEO CARD U CAN TRY REMOVING UR GPU FROM UR MOTHERBOARD AND TRY CONNECTING THE DISPLAY WITH ONBOARD VIDEO DEVICE OF UR PC IF U STIIL GET THE PROBLEM EVEN FROM UR ON BOARD GRAPHICS CARD THEN SOME OTHER COMPONENT MIGHT HAVE MALFUNCTIONED NOT UR GPU.
Posted on Sep 19, 2008
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
Hi, During startup, I inserted a USB memory stick and now my screen is all messed up. It is green during startup instead of blue, and in general there are too many green pixels. (and purple pixels too) I...
remove the memory stick then try to boot up again, if still the same try to boot up under advance boot options, pressing "F8" repeatedly on the way up of boot up (from off to on) go to safe mode then try a system restore, see if that helps
Mar 23, 2011 | Medion Computers & Internet
I have forgot my password for my computer and cannot access as the administrator only can access my daughters account which has limited privleges
When you boot up to the log in screen type in administrator to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
or
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Dec 07, 2010 | Acer Computers & Internet
Forget password . . . cannot open ...
or
hope this helps
Dec 06, 2010 | Acer Aspire 5100 Notebook
Logging in problems
Download minipe, put it on an usb stick, go in the bios by pressing del or f2 when your laptop just starts booting and change the boot sequence to usb first, when in minipe at the harddisk part press on chkdsk.
Jun 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer lcd tv screen goes fluro green, only on some pixels not entire picture but rest of screen is not a very clear picture.
my acer lcd 32" tv just recently went of the blink. It has vertical, horizontal lines and fluro green screen. please need some advice...
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
Computer loading/splash screen pixilated and distorted
if you can, hook the computer up to a different monitor and see if it does the same thing. It sounds like it is an issue with your monitor initalizing but the reboot can complicate things. Also if you have a cd that came with the computer you might want to put it in and see if you can re-install your video drivers. One last thing is to check and see if the reboot might have changed some of the settings on the monitor itself. See if you can reset to factory default or an auto adjust. It depends on the kind of monitor as to wich option you can do
Jan 02, 2009 | Computers & Internet
Computers & Internet Logo
370 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
