Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Color is washed out ,almost black & white - Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
  • 927 Answers
Good Day;
Washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Good Luck, big IRISH. PS: don't change any other setting!!
Posted on Sep 19, 2008
Black & Decker 1710 type 2 miter saw need to wire switch and do not remember the wireing diagram. I have black & white from source or plug, and red & black from the motor. What color wires go where?
White and black from the cord is LINE. White is neutral and black is hot. On the motor it is insulated and does not matter but usually red would be hot. That is the load.
Oct 22, 2017 | Washing Machines
Need to what panel to replace on my samsung hdtv
Please include the model# of the TV. This helps in dagnosing the problem.
Feb 19, 2016 | Samsung Televison & Video
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
My washing machine is an lg 2277hb not hw. Does it make a difference
No, the letter b means that the color is black. W means the color is white.
May 25, 2011 | LG WM2277H Front Load Washer
Problem with printing black and white photos
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
May 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
Replacing front turn signal socket on 1990 dodge shadow
Okay. Hook black to black.
Green to green with white stripe.
Yellow to red with white stripe.
That should work. Nothing is going to blow up if it's wrong. It just won't work.
May 15, 2009 | 1990 Dodge Shadow
Washing machine moter
green is ground, white is neutral, red/black is usually hot on a 1 phase 110-120v motor. (normal colors are black, white, green).
if three phase, (208-220v), green is ground, white, is neutral, black/red/blue are hot. (only uses 2 of these, so there should only be a total of 4 wires). once you have the wiring connected, turn on the motor, and check the rotation direction it turns. if it turns backwards, reverse the red/black wires, the red/white wires, or the black/white wires.
be sure you look at the data plate on the motor to determine one or three phase motor.
their should be a small diagram of which wire inside go to which other wires inside on a three phase motor and for which voltage, and are usually numbered on the individual wire.
good luck.
Nov 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool duet HE pump wiring
2 blacks to one valve and whites to the other,def. same color to both terminals, and should be obvious by length of wire which goes to which, if not run before closing top to be sure hot/cold not reversed
Mar 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
