Question about Kenmore 24032\24036 Top Load Washer
KENMORE SERIES 80 WASHER
  1. SOME TIMES THE WASHER DOES NOT DRAIN ALL OF THE WATER AFTER THE LAST SPIN CYCLE, ANY IDEAS
  • 1 more comment
  • spotdog19 Jan 24, 2009
    After washing a load, all the water doesn't drain out and clothes are more wet than usual after the spin cycle (we always do a 2nd rinse and spin). We pulled apart the machine and made sure there wasn't anything plugging the pump or the lines. This is a Series 80 model 110.18****.
    It does appear that the tub may not be spinning as fast as before, also there is an audible noise as if it may be scraping or grinding against something.
  • sparky3342 Jan 26, 2009
    does't drain water after last spin clothes still wet finishing cycle
  • Anonymous Mar 23, 2014
    series 80
    Novelist:
    Champion:
  • 261 Answers
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Posted on Sep 15, 2008
  • 99 Answers
SOURCE: Kenmore 80 series
sounds like your control switch needs replacing.
Posted on Apr 30, 2008
  • 112 Answers
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
If the unit is still agitating as it is supposed to, this is usually due to a faulty lid switch.
Posted on Oct 25, 2008
  • 686 Answers
SOURCE: Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Posted on Apr 17, 2009
mgprice
  • 744 Answers
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 14, 2009
TheMobilian
  • 8205 Answers
SOURCE: I have a Kenmore 80 series washer the spin cycle
Well the pump is mounted on the motor360f347.jpg and the motor is attached to the transmission. So the motor must be running to get the thing to pump or spin. I am thinking then you must have a problem with the lid switch.c5d56fd.gif The switch has 3 wires. A green grounding wire which is attached to the case, and 2 other wires which carry live current. One thing you can do to SEE if that lid switch might be bad is to bypass it. Unplug the lid switch connection and jump between them 2 live wires. If she takes off a spinning then you know you need another one. You can leave it jumped but it might be dangerous to children.
I have a ton of more info on this at my blog page on these wonderful machines HERE
Posted on May 26, 2010
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
80 Series Kenmore Washer, No draining or spin cycle
It does sound like a controller problem. Go to: SearsPartsDirect.com for parts diagrams and part numbers.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Apr 17, 2009 | Washing Machines
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
No spinning
95 percent of the time this is caused by a defective lid switch.
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
212 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
