Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 5315 dishwasher
I opened the dish washer while it was running to add a dish. When I shut the door, it does not run any more. Yes it does have power at to the unit. please help!!!!
  • Anonymous Mar 24, 2014
    dishwasher wont run at all and non of the lights come on. however there is power to the housing board
You can try tripping circuit breaker OFF, then ON, Can't hurt.
Check manual for reset procedure like hold down Normal wash and Delicate/econo wash at same time and push POWER ON.
Manual for 5300 series may be on line at bosch.com
Posted on Dec 07, 2007
    Champion:
  • 277 Answers
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Posted on Jan 31, 2006
Why is my dishwasher is stuck in the drain cycle
What kind of dish washer. It sounds like the switch is stuck try giving the dish washer a through cleaning.
Aug 13, 2014 | Samsung DMT400RHS Builtin Dishwasher
Beeping won't stop at end of cycle
Our Bosch does the same thing, we just open the door shut of the power and close the door again so the heat can sanitize the dishes. I don't recall if there is an alert off button though.
Jan 08, 2014 | Bosch SHU9926UC Built-in Dishwasher
Bosch shv46c03uc
I would check the latch on the door..When you shut the door it makes contact telling the washer it's closed
Aug 17, 2013 | Dishwashers
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
The dishes are pretty wet as is the inside of the dishwasher after a regular run. will a rinse agent fix this?
Rinse aid will help.The Bosch dishwasher uses the captured heat from the water to dry the dishes.turn on your dishwasher ,wait 20 mins and open door .Does steam come out?if yes rinse aid should do trick,if not water is not heating and you probably have a bad e.control (common problem)est repair cost in Boston area $229.. Hope this helps ,please rate my response :)
Dec 08, 2009 | Bosch Evolution 800 SHE68M05UC Stainless...
Bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Apr 09, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Not enough water Pressure to clean dishes, 6yr old Bosch
Replace the pump, if you go through the trouble of repairing the pump and all the disassembly and then more problems will probably ensue. As far as location it is usually located under the washer. Accessed through the front service panel. Make sure you follow all safety procedures #1 being unplug the washer or turn off breaker prior to proceeding.
Feb 13, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
My dish washer won't stop trying to drain
my dishwasher would fill up and start draining when washing watt should i do
Nov 24, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
1,187 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
