Question about Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob error codes
I have a kenmore calypso elite washer. It stopped in the middle of a wash and displayed the message "Ld". I assumed that meant that the load was off balance. So I redistributed the clothes and tried again. Nothing. The clothes are soaking wet, so I pressed CANCEL and tried to just run a RINSE/SPIN. Then I got an error message that said "Ob" The washer came with the house when I bought it almost 6 years ago, so I don't have the user manual. How do I fix this?
  • 1 more comment
  • billwill4u Sep 15, 2008
    Same here...MaryJo114- did you find a solution?
  • Anonymous Dec 05, 2008
    I have a kenmore calypso elite washer. It stopped in the middle of a wash and displayed the message "Ld". What do I do
  • Michael_even Mar 22, 2009
    I believe I have the same problem with debris caught in the pump suction hose.  How do I access the pump suction hose to properly remove the debris?
  • 412 Answers
Hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Posted on Mar 20, 2009
  • gwgranger1 Sep 17, 2011
    I know this is a very old post but my machine just did the same thing. Turns out there was a lot of coins under the agitator and drum that stopped the water from draining out. If the machine senses all the water is not out it does the LD ob errors.
    New Friend:
Turns out the outer tub on these things contain two rubber balls that act as check valves, mine was missing one, so it would not drain, even after someone replaced the pump motor. Getting a ball in there is another story. Hope this helps....
Posted on May 29, 2016
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Code Ld and sometimes Ob water doesn't seem to drain properly
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@&^$
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
I have a kenmore calypso elite washer. It stopped in the middle of a wash and displayed the message "Ld". I assumed that meant that the load was off balance. So I redistributed the clothes and...
lean washer back remove bottom cover have towels handy remove bottom cover on pump (if it has them) clean pump..if it doesn't best replace pump older pumps had spines that would strip out so pump would pump out the water
Sep 07, 2008 | Washing Machines
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
781 people viewed this question
Dan Webster
Dan Webster
Sal De
