Question about JVC Everio GZ-MG130 Camcorder
Camera temperature is too low
Since I came back from Brazil my camera doesn't work and keep posting the message: CAMERA TEMPERATURE TOO LOW KEEP CAMERA POWER ON, PLEASE WAIT.
I left the camera on during the whole day and it continue showing the same message, what should I do to solve the problem.
My camera model is GZ-MG130U
  • mr_sinhaak Sep 17, 2008
    I have the same problem
  • deepapaul Dec 12, 2008
    I have the same problem . But my camcorder is jvc GZ-MG155U
  • 11 Answers
SOURCE: DOWNLOADING FROM JVC GZ-MG130U
Have a look on the site http://www.convertmod.com, you will find your happiness with this wonderfull software that converts .mod files and that converts .tod files
Posted on Jan 14, 2008
  • 15 Answers
SOURCE: I have a JVC gz-mg130u HD camcorder that willnot work in Vista
The short answer is that unless JVC have released a firmware upgrade to this model, currently its not support for use on vista.
You can try here though, for some upgrade info,
http://support.jvc.com/consumer/support/index.jsp
Thanks
Posted on Dec 10, 2008
  • 259 Answers
SOURCE: CAMERA TEMPRATURE IS TO LOW PLS KEEP CAMERA ON
you must be trying to operate the camera in a cold area when the cold gets to the camera it forms moisture leave it turned on until it warms up hope this helps regards Jim
Posted on Apr 24, 2009
  • 107 Answers
SOURCE: jvc hdd everio GZ-MG130U need manual
Hi
Here is the link to download manual for your JVC
http://resources.jvc.com/Resources/00/00/91/LYT1668-001C.pdf
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 20, 2009
SOURCE: i lost my cd rom for my jvc hybrid gz-mg130u is
I found the cd rom in california
the part #cd rom assembly ly35273-014as
andrews electric 1-866-257-7700 ext213 hAVE CREDIT CARD HANDY
Posted on Jun 23, 2009
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Sep 25, 2017 | Pentax Optio M85 Digital Camera
When i open my cam it shows" camer has too low temperature
You may at extreme low temperature that cause your camera freeze. Check the temperature working range in your manual.
regards
Dec 17, 2010 | Cameras
My camera is saying, "Camera
first put it on the charger for a couple of hours(while its powered off) then see what happens when you turn it on
Oct 28, 2010 | Cameras
I have a JVC HDD Camcorder GZ-MG135AA. I've had it for a while but it has a HDD error and it also says "Camera temperature is too low, keep camera power on?..what can I do to fix this?
The best solution is to send the product back to the manufacturer for repair or replacement. If you have a receipt for the product and its within the warranty period (1 year) they will do this free of charge. I can help you with the process.
Muzu
Nov 12, 2009 | JVC Everio GZ-MG21 Camcorder
JVC Everio GZ-360BU Camera Temperature is Too Low - Keep Power On??
I'm an English guy with the same problem... What you do is keep the power on for a long time, or you charge it up with the charger. Trust me. However, it is very rare for this to occur. There should be a message saying: "Temperature is too low, keep power on." There should be another message reading: "Turn off power and turn on again to check if camera is fully-functional. Thanks for giving me something to do while X-Plane downloads on my Mac OS X.
Oct 31, 2008 | JVC Everio GZ-MG30 Camcorder
Camera Temperature
mine is an everio gz-mg37u and i get that same bulls*** on the screen at every power up. First I tried waiting a while then switching all the switches between camera and video mode, record and watch mode, etc. and one time it worked and the message went away. Haven't been able to do that since.
Now what I do is turn it on, wrap it in a blanket, leave it about 10 minutes, then turn the power off and on again. Works fine for me, and if I turn it off and then turn it back on within a few minutes before it cools down, it works fine. There has to be a messed up sensor in this thing that I can desolder somewhere......
Jun 13, 2008 | JVC Everio GZ-MG130 Camcorder
Temperature to low
When we turn the camcorder on there is a message on the screen which says the temperature is too low and we have to wait. We have left the machine on several times and the message remains and the machine don't not do anything. Any Idea on how solve it?
Feb 21, 2008 | JVC Everio G Camcorder
Getting great pictures
Here are some tips for taking great pictures with your PDC 700 camera: * Keep the sun behind you or at your side. Avoid having the sun directly overhead. * Use the Flash On setting if there is a light behind your subject. * In low light conditions, use a tripod to avoid camera movement during exposure. * When possible, take pictures when the temperature is between 13C (55F) and 35C (95F). Temperatures outside this range can affect battery performance. * Keep the subject within the flash range of 18 in. to 10 ft. (0.45m to 3m.) * Avoid shooting toward reflective objects, which can result in "hot spots" in your pictures. If you cannot avoid shooting toward reflective objects, use the Flash On setting . * Periodically clean the lens, the LED area on the front of the camera, and the LCD display on the back of the camera. Use a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Does heat effect the performance of digital cameras?
Digital cameras have a specification for ''working temperature range''. This information is usually found near the back of a User's Manual, in a section called Specifications. I just check the User's Manual for a Canon DSLR 20D and the specification for working temperature range is: 0 to 40 C 32 to 104 F
Sep 06, 2005 | Olympus Camedia C-765 Digital Camera
"High camera temperature"
If there is a memory card inside the cad slot, take it out first. Open the camera. When the "high temperature camera" error appears, after it goes off, "BLOW AIR INTO THE CARD SLOT BESIDE THE CAMERA SEVERAL TIMES. I have blown air manually by my mouth. Then you can put back the memory card back or you can just simply Turn-ON sa camera. See if it work. It works fine for my CX7530 (i got this idea thru trial & error). Stupid kodak service center won't help, they just want to service my camera for almost half the price that i bought mine, & even suggested that i  should buy a new one.
I hope this works for you. ----kodak camera user from the Philippines.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
JVC Everio GZ-MG130 Camcorder Logo
76 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
