Question about RCA RC6001P DVD Player
Input password screen
The rcs dvd players works fine. Except with one of my western movie dvd. I load the dvd in the players and a input password screen appear. I enter the "99999" default code and that doesn't work. I find the password section in the menu and change the code to "12345" and unable the parental lock. Nothing new happened! The dvd player always ask me "input password" at the screen. Even if I set the operatin language in french...
    Champion:
  • 277 Answers
I believe that the problem is in the movie itself it has a password somewhere on the case try playing it on antoher dvd , c if it does it agian windman
Posted on Jan 31, 2006
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
Mar 24, 2011 | Toshiba SD-K740 DVD Player
WHATS THE HACKING CODE FOR MY JVC XV-N322 DVD PLAYER
Try this link: http://www.videohelp.com/dvdhacks/jvc-xv-n322s/5424#30023
1. When "REGION CODE ERROR" shows on screen after you've input your wrong-region DVD you push "ON SCREEN".
2. When the DVD-menu is showing push "ON SCREEN" again and another DVD-menu will appear.
3. Move the arrow over to the clock and press enter. The menu asks for "TIME" and you write 0:00:00 and push enter.
4. You will now see the menu for the movie. Remove the DVD-menu by pushing "ON SCREEN" once. You can now watch the movie.
(Tested and Worked!)
Report this hack (requests/questions/spam/wrong/****).-->
icon_minipost.gifRegion code hack posted by Alex2000, October 31 2009:
Your hack is GREAT!
Works fine on the JVC XV-N342 too.
And right for JVC on the ESS chip:
JVC XV-N320, XV-N322, XV-N330, XV-N332, XV-N340, XV-N342
and so on.
Thanks!
Mar 05, 2010 | JVC XV-N322 DVD Player
Movie wouldn't play
I needed to enter a password to use without parental control. Works fine now.
Thanks
Jun 13, 2009 | GPX PDL705
Passcode
Step 1
Place a DVD that prompts you for your password in your PS2. If you have any R rated DVDs sitting around, one of those should work just fine. It should prompt you for the password before anything else comes up.
Step 2
Select "Yes" to playing the movie and select "Yes" again to temporarily suspend parental controls. This is where you would put in the password if you knew it and the DVD would play. You may try "1111" at this point, as it is often the password. If that doesn't work, continue through the next few steps.
Step 3
Press the "Select" button on the screen that wants you to input the password. This should change the text on the screen from "Enter Password" to "Delete Password."
Step4
Input the numbers "7444" into the box on the screen. This is the universal password needed to delete the current password. Once you input the numbers, you should get a message that says "Deletion Complete." Press the "Select" button again and you should be prompted to enter a new password.
Step5
Enter a new password for your parental control. Make sure it is something easy that you will remember. Once you enter it in, you will be asked to confirm your new password. Enter it one more time and you should be able to watch any DVD you want.
hope it helps!please rate if it does!
Nov 07, 2008 | Sony PlayStation 2 (PS2) Console
JVC XV-N212 DVD player - unlocking region code
It is not a permanent hack, you will have to to it over for every movie you put in.
Don't think theres a pernament one for this player yet but i'll try and post it on here if i ever find one. Sorry.
Oct 15, 2008 | Televison & Video
Password request
Something must be set to restrict certain movies and it is protected by a password. Did you do this to protect your kids? I would dig out the manual and see if this is the case.
Aug 22, 2008 | Polaroid DVP-1000
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
Jun 29, 2008 | Toshiba HD-A30 HD-DVD Player
Changing the region code
This unit is hard-wired to be the region for which it was sold;sorry...accordianman
May 09, 2008 | JVC XV-N212 DVD Player
Making my DVD Player Region Free
It is not a permanent hack, you will have to to it over for every out of region movie you put in.
Mar 30, 2008 | JVC XV-N212S DVD Player
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
RCA RC6001P DVD Player Logo
475 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
