Question about Car Audio & Video
Cassette tape is stuck in player-car is a 95 buick lesabre.Can you help us to get it out?
  • bournegail Sep 08, 2008
    It's not no fun driving around from place to place without being able to listen to the old music from back in the day!!!!!
    I DON'T HAVE A PROBLEM WITH CAR SPEAKERS NOR SUBWOOFERS.
This is what I NEED is a solution to this problem---THERE IS A CASSETTE TAPE STUCK IN A CAR STERO. The cassette player will not eject the tape. Does anyone have any ANSWERS?
Posted on Sep 08, 2008
How do I clear code E10 off my radio
Rance, possibly errer code will go away if your battery was unhooked for ten minutes and reconnect.
E10 : Tight tape error
Cause: A restricted casset tape transport or broken cassette drive belt
Substitute a different tape. If there still is an error code, service the unit at an dealer/ Service Center.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread How to reset radio code in 2002 Buick Century and will GM charge to...
CD Player gives E20 error code when CD is inserted GM Forum Buick Cadillac...
Jan 29, 2016 | 2000 Buick LeSabre
Tape is stuck in my 1990 buick reatta
Turn the power on the radio Cassette hit eject turn the power off turn the power back on. The cassette may come out unraveled but that's only way I can think of you will get it out.
Jul 19, 2013 | Car Audio & Video
How do you get a tape out that is stuck
Probalby the only way to get stucked tape out of a player is in pieces. Then repair the cassette and clean your player. If it keep stcking tapes, dispose it.
By the way, cassette tapes an players are rather obsoleteby now. Any digital source is better quality the a cassette.
Aug 28, 2010 | JVC TD-W118 Single Cassette Deck
My tape is stuck in the cassette player how do i
I've done this by using a small screw driver and gently prying up on the tape while holding down the Eject button.
Jan 31, 2010 | 1997 Buick LeSabre
95 lesabre wont start.new plugs and wires. fuel pump is working.
may have bad horn relay, for the no start check key chip and ignition switch could have bad chip contacts or just bad switch. hope this helps.
Oct 09, 2009 | Buick LeSabre Cars & Trucks
Cassette tap stuck in the player in car
Get a new radio from Crutchfield.
Apr 06, 2009 | 1998 Buick Regal
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
Buick 2002 I have a cassette tape stuck in the
fast forward cassette then rewind till it stops then it should be able to eject
Mar 13, 2009 | Car Audio & Video
Have a cassette stuck in my 98 Buick Century Custom
sometime you can get luck by taking out the tape player and there will be a small hole somewhere on the player that you can stick a paper clip through to release the tape player. Otherwise gnetly stick a screwdriver under the tape to see if you can get it to release. no guarntees on that last one
Jan 08, 2009 | 1999 Buick Regal
Car Audio & Video Logo
315 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
