Question about JVC Everio GZ-MG130 Camcorder
Writing DVD is not seamless
When I try to record a DVD they are not continuous. they are saved in segments that mach when I stop and start recording. In another word as I'm recording an event I start and stop many times, this is how my DVD come out (not playing continuously) there is a couple of seconds freeze between each (file ?). At the same time if I would to play them directly on my camera LCD they play continuously?!!!. Any one can help me to figure out a solution?
  • 3 Answers
Not only you. A lot of people have same issue.I have read a lot of questions and answers,forum about JVC software Power cinema ...etc... ( go to www.videoforums.co.uk/general-sofware-problem/12080-jvc-everio-sofware.html ).Headache.That sofware from JVC is a scrap.
Buy a DVD Recorder ( cheap one ) . Record directly from your Camcorder on Replay mode. That is my way.It is good.
Please tell all of your friends,family , co-workers never buy any products from JVC again. NEVER all your life.
Posted on Sep 14, 2008
I have a DVD/VCR recording device and I need to hook up my camcorder to record videos to a DVD to submit to an organization for my son to receive a service dog. I can hook up camcorder straight to TV...
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
See page 21 of the manual for the GR-D347U. Treat the DVD recorder as a VCR for this situation. The manual is available here: https://www.manualslib.com/manual/82266/Jvc-Gr-D347u.html?page=21#manual .
I hope this helps. Please add a comment with the details of the DVD recorder for more information on connecting the unit in this daisy chain.
(Many recorders have at least two composite video Line In inputs. That's why you need select the correct one for recording.)
May 19, 2017 | JVC GR-D347U Camcorder
I am trying to save a DVD + R disc to my lap top so that I can make more copies of it for Family. I get an error message when I try and do it. ''Your recording device does not support writing to DVD media....
The error message implies that your DVD is not capable of writing DVD's, particularly DVD+R disks. Recheck the spec's on the drive; it might write to DVD-R disks, or perhaps it only burns CD's and not DVD's at all.
Nov 16, 2009 | Computers & Internet
Starts to record ,then it will record for awhile,then stops,says clean dis.that don't help
Try to use a lens cleaner. If that doesn't help, then the writing part of the lens is going out and needs to be replaced.
May 14, 2009 | RCA DRC8295N DVD Recorder/VCR
Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
May 01, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
I am trying to record from my dvr to my magnavox 10d6 recorder
Connect the yellow/red/white out from the VCR to the same inputs on the 2160. Press setup. select general. select video select video input. select L1 or L2. press ok. select video or s-video.
press setup to exit.
select HDD or DVD (whichever you want to record to)
use source or channel to select L1 or L2
press rec mode to select sp/lp/ep/etc
press record to start recording
start playback on the input device
press stop to stop recording.
The manual is available as a PDF file on the web. It would save a lot of typing...
tom
Jan 20, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Lite On disc writing failure
try updating the rom by downloading from lite-0n
Mar 27, 2008 | Lite On LVW-5006 DVD Recorder
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
Wharfedale dvdr24hd160 - Segment or split hard drive recordings
Wharfedale dvdr24hd160 I can not get the set up display on TV i have just the sound...!  Would you please help me. Thanks, Moon
Jan 14, 2008 | Wharfedale DVD-M3 DVD Player
Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Dec 24, 2007 | Emerson EWR10D4 DVD Recorder
JVC Everio GZ-MG130 Camcorder Logo
64 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
