Question about Pioneer PD-R509 CD Recorder
Teac X-10 connections to a dbx 224
Please can anyone help? I have a Teac X-10 reel to reel recorder and a dbx 224 unit. I am not sure how they need to be connected to use as there is nothing about connections in the Teac manual even though it is designed to operate with it and discusses its use. The dbx manual only shows a normal set of tape conections not dbx specific additional ones as found on the Teac rear panel.
    Champion:
  • 277 Answers
Connect the x10 outputs to the dbx 224 line in connect the dbx 224 outputs to the cd recorder anlog line in windman
Posted on Jan 31, 2006
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
Looking for a Teac X10 reel to reel recorder User manual Not service manual Can anyone help please?
It should be found as a Pdf file on Hi FI Engine or for $5.00 at owners-manuals. com as these places usually have the common manuals.
Mar 19, 2015 | Teac Audio Players & Recorders
Reel recorder
The A4070G can record in each direction but has a switch that needs to change to switch the heads. This must be stuck after all this time and so the deck needs service. They are not easy unit to work on. I have one in my shop now. The bad news is that they use combo record and erase Ferrite heads that can not be sourced anymore.
I am very familiar with this model as I worked at Teac and fixed many of them.
Apr 20, 2014 | Teac Audio Players & Recorders
Teac A-5300 reel to reel service manual
Try Hi Fi Engine first and then owner-manuals.com and the best solution is from stereomanuals.com which is where I get my manuals.
http://www.stereomanuals.com/index.htm
Jan 04, 2013 | Audio Players & Recorders
I have a Teac A-1500 reel to reel tape recorder and need a drive belt for the capstan, Can you help me?
Contact: pjheiland@hughes.net He can supply drive belts for Teac reel to reel recorders and other manufacturers units.
Mar 31, 2011 | Teac Audio Players & Recorders
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
May 11, 2010 | Audio Players & Recorders
I'm trying to connect a dbx 128 and 118 to my adcom565 preamp, teac tape deck, onkyo tuner, anf radio shack cd recorder, but i'm not sure it can be done. Can anyone help me?
Of course it can be done.
I'm wondering, what's the NEW piece of this puzzle? New dbx gear?
The preamp has two tape loops plus a processor loop (essentially 3 tape loops). You can discount the tuner for this discussion as it already has a dedicated port.
Here's what I would do (and have done *). Get yourself a dbx 400 or dbx 400x Program Route Selector and simplify all of your current and future analog hookup options.
(* I, too, have a CD recorder and a tape deck plus some different dbx units (4bx, 110x-ds; 224) and other toys.)
One on eBay at $59 (a steal so far) expiring Mar 9:
http://cgi.ebay.com/DBX-400X-Sound-Processor_W0QQitemZ270540334138QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3efd75e43a
and a link to the manual so you can see how it works:
http://www.dbxpro.com/product_downloads/Owner_Manuals/400%20Owners%20Manual.pdf
It takes up ONE tape loop and allows attachment of 3 processors and 3 tape decks PLUS a dbx-style noise reduction system if you have one; and can logically rearrange the processors to be in line with any source and BEFORE, AFTER or BETWEEN tape decks with or without the Noise Reduction Processor involved, all via front panel illuminated buttons.
If you don't want to go the 400x way your options are severely limited re: the tape deck because even though the dbx processors can fit in nicely on the preamp, I don't think the preamp can place them in front of AND after the tape decks, depending on your desires for pre- or post-processing.
Mar 02, 2010 | Bose 901 VI Main / Stereo Speaker
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
DBX 119
Do you mean you are just going to play back dbx-encode tapes that have already been recorded? Or both playback and record new material? Please explain.
Aug 25, 2007 | DBX 1231 Home Equalizer
Pioneer PD-R509 CD Recorder Logo
691 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
