Question about Zanussi Washing Machines
How to fix anew door seal on a Zanussi FL1081
    President:
  • 1,462 Answers
Turn off atmains
remove the clamp that secures seal to cabinet and peel away the seal.
the seal is held onto the tub by a large spring. at bottom, pull hard down and out and seal will come away.
on new seal, lubricate the slot that goes onto the drum rim with washing up fluid.
start the slot onto the drum rim at the top and work your way round in both directions pressing slot onto rim. this is quite hard work and you may need several attempts.
when slot is on rim all the way round, refit the spring into the outer slot of the seal. this is quite difficult and an extra pair of hands helps
refit seal onto cabinet rim - this is easy and refit outer clamp.
test on rinse cycle for leaks as the water level is higher.
water will foam till the washing up fluid is washed away
note that the seal has a specific way up indicated by an arrow
Posted on Sep 07, 2008
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
IS IT EASY TO REPLACE THE DOOR SEAL/GASKET ON ZWF1430W
it is very very difficult to replace the door seal on a zanussi washing machine, its best fitted by an engineer
Feb 03, 2010 | Zanussi ZWF1430W Front Load Washer
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
Water is leaking from the door seal I need to
Before you remove the door, be certain the bottom seal is not folded forward so that it does not seal. I fixed mine by opening the door partway and running my finger along the bottom, pressing the seal back in. If you need the manual, it is here: http://www.manualshark.org/b/zanussi-6/ One of my favorite appliance help websites is: http://fixitnow.com/
Oct 31, 2009 | Dishwashers
I am having problem putting anew door seal on a
hello it a tricky job ,take the top off the washer look down you should see a metal ring with a screw on it . unscrew the the ring it should come apart . then you be able to pull the seal off . the on the front of the washer around opening of the door is a clip with 2 screws unscrew this there should be a metal wire take this off and pull the seal off and the whole seal should come off when you put the new 1 on put the seal on the drum first and don't forget to put the metal ring back on all the best
shaun
Aug 07, 2009 | Washing Machines
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
May 21, 2009 | Refrigerators
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Nov 26, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi jetsystem 1400 door seal
IF YOU REMOVE THE SEAL UNLESS YOU ARE AN ENGINEER YOU WILL FIND IT EXTREMELY DIFFICULT TO REFIT IT, TO CLEAN OUT THE SLUDGE USE A PLASTIC SCOURING PAD LIKE THE ONES USED FOR CLEANING DISHES. IFTHE SEAL IS BLACK THIS CANNOT BE CLEANED IT IS A CHEMICAL REACTION TO DETERGENTS ETC BUT IS NOT HARMFUL TO ITEMS BEING WASHED HOPE THIS WILL HELP.
Oct 09, 2008 | Zanussi ZWF1440 Front Load Washer
Washing Machines Logo
95 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
