Question about Whirlpool Duet GHW9150P Front Load Washer
Latch wont close shut
I cant get my door to shut
  • 750 Answers
Turn,
This is a matter for service .
If you never fixed washers before you need to have a pro to diagnose and replace the electronic malfunctioning part!
Sorry but you need hands on help today!
Bless You huuum.
please rate me for my good advice!
Posted on Sep 12, 2008
Door wont latch
FIX CAR DOOR LATCH - YouTube
? 1:29
https://www.youtube.com/watch?v=wmWsM-TSaKo
Oct 21, 2011 - Uploaded by benherrerajr
Ever had a car door that wouldn't close? If the latch was accidentally stuck down, then here's the most ...
DIY Fix & Repair For Car Doors That Will Not Close
finley.xyz/diy-fix-repair-for-car-doors-that-will-not-close/
You are out and about and your car door suddenly won't close and stay shut. ... should be your first go to choice for repairing a car, truck or vehicle door latch of ...
Car Door Won't Close or Stay Shut - JamesMaurer.com
Jan 16, 2016 | Cars & Trucks
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Door wont latch shut
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
My cars driver door wont close. dont kno if its the door hinge or the bolt but i cant get the door to close and because of that it keeps draining the battery. and its pretty dangerous driving
There are some jaws,on he door latch,make sure the door is unlocked,and pull the jaws open,while pulling on the door handle like you are going to open it,the jaws on the door latch should release and open,then try and shut the door closed.
May 03, 2010 | 1994 Ford Thunderbird
2006 slider door latch problems
make sure the latch is open, use a screw driver, stick it in the middle of latch where the striker would latch the door, now open handle as if your opening the door hold handle in that position and pull screwdriver out slide away from door to open the latch,latch might have closed it self, try that first, hope this helps.
Dec 06, 2009 | 2006 Kia Sedona
Rear door won't stay shut
Check the latch mechanism on the door. There is a piece of the latch that closes around the clasp on the door frame. sometimes this closes when the door is open and you can't shut the door. Take a screw driver and flip this latch piece open and close the door.
May 29, 2009 | 2008 Chevrolet Hhr
Chevy Blazer door wont close....
Not sore if you have the answer or not. Here it is. MANUALLY place interior door lock latch in the UNLOCK position. Now LIFT UP outside door handle as if opening. While holding it up with your finger ( no prying ) lift up closed latch. Now you should be able to close your door normally.
Apr 01, 2009 | 2002 Ford Escape
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
