Question about PC Chips MB PCCHIPS M863G V5.1C w/XP2400+ Motherboard
Boot problem Recently I had to change the resident battery in the Mother Board of my PC (M863G V5.1D), because a message accused: "week battery". But BIOS refused to work correctly, not importing that I have executed the correct procedure I noticed that Clear CMOS jumper was open (normal position - pins 2/3) and I left like this. But now the PC only opens for CMOS and don't retain the necessary configurations for normal doing. I ask if it is necessary to update BIOS or only to reset it. I will be thankful for your answer.
    Novelist:
    Scholar:
  • 64 Answers
Updating the BIOS could be the solution, but, let's leave that until last - if you get it wrong, you'll stuff up your machine (mobo) for good.
Don't worry about the CMOS jumper, it is there to clear the CMOS memory, but I don't think you need to do that.
Can you get into your BIOS during start up OK? (usually by hitting F8, F2, Del one of these keys or similar during start up, it should tell you which).
If you can navigate your way through the BIOS settings ok, don't change anything you're not familiar with - another place you can do damage, and somewhere towards the end, where you have to option to exit BIOS with or without saving there should be another option like "Reset Defaults" or "Load Optimal Settings" or "Set Last best Settings" or something like that.
Click on this then exit your BIOS. Your computer should restart.
Make sure your new memory battery you put in is up the right way, if it's upside down it could be causing a short - the usual way is positive up, that's the whole flat face with the writing on it - the insulated button side is negative (down).
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 02, 2009
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
M863g v5.1a sempron cmos clock error solution
Hello here is the mainboards homepage:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=343&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
For downloading the manual.
The solulion is, to renew the cmos battery on the mainboard.
The battery is a cr2032 watch type:
Press the lid to release the cmos battery, and insert the new the same way.
Restart the pc, and you probably get this message:F1 or F2 for setup, or press the delete button to enter the bios.
You have to setup the bios, like clock,date,and boot settings for your drive.
Look in the manual, for detailed setup configure.
Good luck
Jan 19, 2012 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Loading pbr 2 done message
battery had all lights lit. Took it out and now the front battery display light is flashing. I have a new mother board could there be a problem with recognition?
Mar 13, 2010 | Dell Inspiron 6000 Notebook
Balance board will not stay on
If you have already changed the batteries then the problem resides internally. What you need to do is either take it back to the store where purchased or you need to purchase a new one.
Mar 04, 2010 | Nintendo Wii Fit for Wii
My HP Laptop suddenly started showing vertical stripes around once a week and could use it anymore until I turned it off. on rebooting, I would hear a couple of loud beeps but the PC will not boot....
There are a couple thing youcould have been looking at. number one a virus(trojan) got into you machine.
Number two you mother board is starting to go.
Number three your video card located on the mother board is gouing bad.
Number four you hard drive is getting weak
The fan on a laptop always runs to keep the machine cool. Smaller spaces get hotter faster.
I think based on your decription it was a virus, make sure you protected. Back up all ou info just incase it is the hard frive is startig to fail.
Oct 09, 2009 | HP Pavilion dv2700t Notebook
Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Jan 29, 2009 | Dell Inspiron 6400 Notebook
Amd socket a 462 manual
The M863G is common with PC-Chips. Look at this link;
http://www.pcchips.com.tw/PCCWebSite/SearchResult.aspx?q=M863G&f=Products&MenuID=104&LanID=2
A snap shot of one of the PC Chips M863G V5.1A motherboard.
http://pcchipsusa.com/prod-m863gv51a.asp
A match for M863G (M863G15CV22ARV000) is a Mercury Mainboard PVCLE266M. Getting any drivers for this is real tough. http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=439 Some drivers will download & other will not.
Check the above links & see if any match you're motherboard.
A visual check. If you see the correct board use the link to download the needed driver/manual.
Mike
Aug 14, 2008 | AMD M863G (M863G15CV22ARV000) Motherboard
Pc will not boot
try looking for CMOS jumpers of mother board
you see it near the battery of the mother board CLRTC
here the link for the manual
http://www.nek.uu.se/StaffPages/CV/CV93.pdf
Page 14
Jun 04, 2008 | ASUS VIA KT133 Chipset A7V133 Motherboard
When booting system I get message: Hardware Monitor found an error. Enter power setup
this is a sign that your cmos battery needs replacing on the motherboard its a cr2032 flat disc shaped battery and normally resides near the memory slots. The battery being flat is losing all the hardware and bios settings, F1 just passes this check and allows a boot, you will probably find the time and date is incorrect which is a sure sign of battery problems
May 27, 2007 | Sony VAIO PCV-RX753 PC Desktop
Computers & Internet Logo
169 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
