Question about Panasonic Microwave Ovens
I was making chutney in my panasonic 900w inverter microwave and had left it on 30 mins having done a number of batches. When I went to check it was completely off, no lights of anything and very hot inside and around it. No burning smells though. I have checked the fuse and it is fine but no lights on at all. Any ideas?
  • Panasonic Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 16, 2008
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Sep 12, 2014 | Panasonic Microwave Ovens
Panasonic microwave problem help needed
Dan, That unit has an inverter, that is the power source for the part that puts out the Microwave energy called the Magnetron. The inverters are expensive and I stopped doing warranty work for Panasonic beacuse of them. Some pencil pusher somewhere though it was a great idea to replace 3 common fairly inexpensive parts. with that dang inverter. Microwaves have come down a lot in cost, I would buy a new one without an inverter. Sorry, wish I had better suggestions, I DO NOT LIKE THEM. LOL Sorry! Panasonic and their distributors are always out of them and there so expensive no one wants to stock them. I have had new ones sent to me that were already bad.
Aug 20, 2017 | Microwave Ovens
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Microwave cuts off after 30 seconds
We would need to know the brand and full model number to be sure, but since you posted in the Panasonic section, I'll assume it's a Panasonic.
Panasonics have preset times in which it will shut off if certain failures occur.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Dec 12, 2011 | Panasonic Microwave Ovens
Error code H98
Hello
Unplug the microwave and plug it back in after 30 seconds to make sure the message did not appear because of a simple glitch. If it does not come up again, use the microwave as normal.
The "H98" error means that the microwave's inverter has shorted out and does not work any more. The microwave cannot transfer power to create heat, and the part has malfunctions and requires replacement. Use your microwave serial number and customer service to find the proper part for the microwave.
Your microwave comes with a warranty that will cover the inverter if the warranty is still valid. Call the number for the warranty department or bring the microwave, with receipt, back to the store you purchased it from. This will save you the hassle of replacing the par
Oct 04, 2011 | Panasonic NN-SD797S Microwave Oven
Left Microwave on while empty
Hi James, Well it sounds to me as the Magnatron burnt out. There are tests you can so, so to familiarize you with what it looks like by copying the link. http://www.ebay.co.uk/itm/PANASONIC-INVERTER-MICROWAVE-OVEN-MAGNATRON-2M236-M42-NN-SF550W-1000W-/262200547027?hash=item3d0c5ed6d3:g:ucsAAOSwSHZWdkWb#ht_1687wt_726
If you are prepared to open up the unit there are a couple of checks you can do on the mag. If you see the item described above in your microwave, chances are its that. With all the video's readily available to view there is little or no point in my describing to you for what to do next so I will advise you look at 'YT' and search for 'TESTING A MAGNATRON' This should hopefully lead you to the conclusion that your Magnatron is faulty.
If it is not, then there is a possibility that the door switches could be at fault, but it's best do do this in a step by step approach to eliminate the issue.
WORD OF WARNING: I have studied electrics but even with my knowledge I received a 250v JOLT across my body due to being careless. I touched the case at the same time as the LIVE in the microwave. DO NOT MAKE MY MISTAKE. IF YOU do not feel confident to remove the cover on the microwave, then DON'T and if you do then then MAKE DOUBLE SURE IT'S NOT PLUGGED IN. I won't forget so easily If fix another.
::((((( . BE SAFE.!!!
Apr 03, 2017 | Panasonic NN-T783SF 1350 Watts Microwave...
PANASONIC INVERTER MICROWAVE
Sep 07, 2008 | Panasonic Microwave Ovens
Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Apr 19, 2008 | Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
