Question about LGDVT418 System
Speakers popping I've had the unit for 4-5 months. It works great and I love it until the speakers started popping. I don't blast it so I doubt the speakers are blown but hey who knows. All the spakers pop now at least once a minute not matter what I'm watching. As time goes by the popping get more frequent. I recently moved and it seems it started popping a lot more but I have it wired exactly the same and made sure no wires are touching, etc.
Thanks I tried fiddling with cords and wires and the problem has stopped for the time being. I've tried all channels right after each other the day I first posted and thats how I know its just on certain things. It definitely has to be the receiver if not the connection, what I don't get if it is the connection than it should be doing it on everything since the sound is built in it shouldn't be affected by other connections. If the problem persists I will call LG and try to get the receiver replaced.
Posted on Jan 31, 2006
  • 513 Answers
Call LG if they are in warranty, should be after 4 months. Try reseating all connections including power, or changing cables. If it shows on all of your speakers, If it doesn't move with one or more speakers, you probably have a leaky capacitor in your reciever and will need to return it for repair or replacement. Hopefully its not just the receiver choosing to spike an amp channel at will. Could possibly be an electrical appliance in your home causing the noise by switching on and/or off. Have somebody walk around your home turning things on and off to see if your receiver is affected. If nothing pops, it very well could be your receiver. An experiment to try is using a different power outlet. Use a long heavy duty extension cord if needed. You want to get power from a different circuit. If that doesn't fix it, try a UPS device (like those used on computers). This will isolate you from the power line, and hopefully from the pops.
Posted on Jan 30, 2006
SOURCE:
Front Speakers stopped working
turn on your video and start something playing, press the speakers button repeatedly until the sound comes back. this should bring back your front speakers, if it doesn't, double check your speaker connections and sound field program.
the speakers button should cycle through all available front speaker options.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
Looking for set up drivers for my old Altec Lansing Speakers
If you do not connect the USB port, the ACS495 speakers should work with any computer OS. (Use the control knobs on the speakers instead of the AMS software.)
I've found the drivers with the AMS software listed here: http://download.driverguide.com/driver/ACS495+speakers/Altec+Lansing/d565728.html for Windows 98 through Vista. (I doubt this has the signed drivers needed to work with 64-bit OS versions. You may be able to get it to run in the compatibility mode for Win7 32-bit. But it may not work on Win7 x64.)
I do not know if this link still works but I don't see any evidence of malware. I hope this helps.
Aug 29, 2012 | Cars & Trucks
My Logitech x540s suddenly VERY loud! HELP
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
if this fails to fix the problem you might have to uninstall your soundcard restart your computer then reinstall it
click start control panel administration tools computer management device manager scroll to sounds and video controllers expand right click select uninstall
then restart your computer and reinstall your soundcard
hope this helps
Nov 21, 2011 | Logitech X-540 Computer Speakers
About a month ago my speakers started humming-does't matter if the cable/dvd are on, as long as the receiver is on it hums. Figured out it was the receiver since I plugged other speakers into my...
normally a Hum is caused by a bad ground,, if it only happens when the unit warms up it could be the output drives are failing. , check the grounds to the unit first, then the wires to the speakers themselves, if they all check out ok,, you need to take it to a repair shop dealing with receivers
May 27, 2011 | Yamaha RX-V1600 Receiver
Hello Audio Gurus..This is my 1st time on here.. I always loved music and I have decided to raise the bar a little in terms of sound considering that I enjoy listening to music more then 2 hrs a day.. I...
No, the CV speakers are very efficient speakers. That means they create a lot of volume for the amount of power. I will start by saying you will be relatively happy but not blown away.
The HK is an alright HT receiver (very new and feature loaded). It makes a rather weak stereo receiver for it is made for a home theater environment. If you only have a pair of speakers (optimal for music listening) then you have paid for a bunch of other channels that will remain dormant. You would be best off to get a very high-power stereo receiver or integrated amp instead of your HK.
CV speakers are built to blast, but they sounds pretty good at the same time.
Feel free to ask me any audio related question, I've worked in the industry for a good part of my life.
Thanks!
Jan 05, 2010 | Cerwin Vega LS-15 Speaker
Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Jul 27, 2009 | Dell Studio 1737 Laptop
M602 Speaker Problem,.. Popping Sound
This worked for me on my M604: Try inserting/removing a headphone plug into the jack several times to see if that clears the problem.
The "popping" sound is very similar to the sound that the unit makes when inserting headphones into the 'headphone' jack on the back of the unit.
The jack has a contact switch that triggers a relay inside the unit. If that contact switch is 'on the verge' of making contact, slight temperature changes may cause deform closer to it's contact target. The subsequent capacitance build-up and discharge across the gap could explain the cycle of popping noises after the unit warms up.
Jun 25, 2009 | Altec Lansing M604 Computer Speakers
Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Jul 08, 2007 | Panasonic CQ-C8803U CD Player
LGDVT418 System Logo
244 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
Mike Duncan
Mike Duncan
pankaj rautela
pankaj rautela
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
