Question about Frigidaire ATF6000ES Front Load Washer
Leaking underneath but all hoses are connected
Can someone help?
  • 1,031 Answers
When a washer is leaking, there are several areas where the liquid could be coming from.
If it only leaks during a spin cycle, it's probably caused by a leaky drain hose
Leaks on a front-load washer can occur around the door seal. This can happen because of a build-up of dirt and soap on the seal itself preventing a proper seal from taking place. Wipe the door seal carefully making sure that the edge of the gasket is clean.
Parts of a plastic bleach dispenser can crack or break off, causing a leak intermittently during the flush process. This is because bleach is a very corrosive chemical. Heavy use of liquid chlorine bleach can pit and rust stainless steel parts..
You'll want to confirm that the fill hoses are connected and properly tightened. Always use new rubber washers when re-installing the hoses. Take care not to over-tighten the connection. Other leaks may be caused by the drain hose being cracked, or by a leaky connection at the water-inlet valve. Too many suds may cause the appearance of a leak when actually it's just a sudsy overflow. Sometimes a drain hose leak occurs at the end of the hose where it attaches to the washer. If the hose is long enough you can cut the leaky end off and re-clamp the hose back on. Usually though, when a hose begins to leak, it is best to just replace the hose.
Many pump leaks happen around the seal on the pulley. Some pumps have a weep hole that lets water drip out when this seal begins to go bad. The solution is to rebuild or replace the pump.
Tub leaks are usually caused by a rotted tub. If this is your problem, consider buying a new washer. Sometimes a constant imbalance can be the culprit. This imbalance can rub a hole in the tub if it consistently runs off-balance. It may be possible to repair the tub with an epoxy kit. Tub replacement isn't usually very economical.
The main tub seal can also leak. This is located where the transmission and the outer tub in the centre. If this seal goes bad, it can be very difficult to replace.
Sometimes the water-inlet valve develops a buildup of mineral deposits and rust. To check this, remove the water-inlet valve and visually inspect the surface.
There is a cool product that is designed to help prevent water damage from a leaky washer. It's called a Washer Floor Tray This tray catches water leaks and prevents floor damage from overflows. This product is a must for upstairs laundries
Posted on Sep 07, 2008
Leaking power steering fluid
Place a sheet of white paper underneath in the proximity of pump and rack. or anything that will show the leak. If you have a set of ramps that would help as well. clean underneath and roll up on ramps check for leaks while running. Or if you have jack stands , puy on that and have someone turn lock to lock while you look for any leaks. I wouldnt just start throwing parts at it
May 13, 2013 | 2003 Cadillac Deville
My Samsung WA5471ABW top- load washer is leaking from underneath. Is there Nything that I can do to self-repair?
You bet there is. But first let's double check some common causes of leaks that may not be located under the machine. Step one is to check the drain hose behind the machine. If a machine gets pushed back too far it can kink or bind that hose and that can cause water to leak from underneath. If that looks okay check that the end of that hose is not inserted into the drain more than about 4 - 5." If it is poked down into the standpipe more than that it can cause a syphoning situation that can also cause leaking underneath. While you are back there check the hoses that lead up to the machine. Make sure the connections are dry. I can't tell you how many under machine leaks i have fixed that originated right there. Just run a finger under each hose connection. If finger gets wet the connection may need tightened ever so slightly with pliers. If all those check out fine let me know. We'll go deeper.
Jan 13, 2013 | Samsung WA5471ABW 27" Top-Load Washer with...
Tricity bendix wdr 1241 emergency drain hose leak
Pull the machine out, if the back is removable, take it off. the connection should be close enough to reconnect...next time? don't pull so hard. if this doesn't work, take it to a reputable Repair Shop/Dealer
Oct 15, 2012 | Tricity Bendix WDR1240W Front Load Washer...
It leaks
where does it leak from,could be drain hose, or pump or connections to and from drain hose and from pump,, look for rusted clamps under neath,,,or holes, also chek waterhose connections,when loking underneath chek for water spots on hoses and pump..
Oct 10, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaking out from underneath
How to Fix a Leaking Dishwasher Hose. *. Whirlpool Dishwasher Connection ... the drain hose pushes water from the dishwasher without water buildup ...www.ehow.com/how_12089937_fix-whirlpool-dishwasher-leaks-underneath.html
hope this will help
Jan 31, 2012 | Whirlpool Dishwashers
Ive had a power steering leak for a little while at first it was small and didnt loss much fluid, but now im lossing power steering fluid in just one day. How do I know if it is a hose that is leaking or...
You need to raise the car, put jack stands underneath for safety and spray some type of degreaser to clean off the oil on the hoses, pump, frame, etc., then wash off with a hose or pressure washer (best). Let everything dry and then have another person crank up the engine while you are underneath looking at pump and hose (be sure your jack stands are securely holding up the car before climbing underneath). If you're losing a lot of fluid each day you should easily be able to see your leak at the pump or hose connections. If it's gotten steadily worse, it probably is the pump seals getting worse.
Sep 07, 2011 | 1999 Mercury Cougar
My kenwood kdw1274w is leaking from under it can you help and bit a lot of water
Check your hoses underneath the dish washer. After a while, they sometimes start to leak where they connect to the pump, etc. Also, sometimes they can crack and start leaking. I would replace the hoses, unless they look fine. Then you should just tighten the clamps on the hoses, if you can.
Mar 09, 2011 | Kenwood Dishwashers
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Washer Leaking from underneath
check the hose from the bottom of the drum to the drain. it probably slipped off. its held on by a tension clip. Someone must have pulled on the hose at the back.
Jan 22, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
308 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
