Question about JVC AV-32260 32" TV
Sgc-8502 circuit board
Does anyone know where I can get this board. One of the switches broke off, then my kid decided to use a scissors to turn the tv on which worked until all the wires were cut off it and the board got trashed. All the sites are saying that it is discontinued.
Yea ... i have one. I'll sell for $129.95. rmainstreet@yahoo.com
Posted on Oct 02, 2008
Electronic circuit diagram for a bass collection bass guitar Japanese 1988
I understand your pain - was googling for similar, and came across this post, 5 years prior. My SGC Nanyo Bass Collection has just started to play silly beggars with the pots, and a bridge fault. Nowhere online seemed to have any details of the wiring, as the problem is, as you say, the fact that all of the tone and volume pots are based on a printed circuit board. If theres a nick or short on the board, its a pig to replace, and I really wouldn't like to have to wire any pots onto it. I'm currently looking at the options of ripping out the old electrics and wiring it from scratch myself. If you're still after answers, good luck!
PS - noted that none of the previous replies are relevant to this - mostly going on about the amps or a Fender guitar??!
May 07, 2012 | Music
I own an Acer Aspire One D250. My kids try to force the wrong ac adapter into the power outlet and it wouldn't accept a charge. Because we own two, I was able to switch out the battery and the computer...
Depends on what damage was caused. If the dc connector broke off cleanly and did not crack the board or caused any other damage, yiou can get a cheap dc socket from ebay from about £3.50, fitting it may cost a little more. I'd get it done by a reliable technician, unless you are handy with a soldering iron.
What worries me a little is the fact it will not boot with the battery, could just be down to the dc jack, but given the fact the kids pushed the wrong adaptor in the socket, it may have caused damage to the charging circuit
Jan 08, 2011 | Computers & Internet
No reverse on drill.
I am assuming the new switch was wired correctly, I would look for the pin or similar device that switches it from for/rev. If your switch has a post look at the slider and make sure not broke or your pin not put in rightt position. Let me know
Apr 22, 2010 | Black & Decker Drills
Shows "safe out" but the magnet is in?
I had the same problem, however the treadmill2_bing.gif remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable connector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Apr 14, 2010 | Bowflex Treadmill Series 7
I-Mate 8502 Ultimate
I have uploaded it to this location.
Hope it works for you!
Cheers! Carlos
Apr 14, 2010 | i-mate Ultimate 8502 Cell Phone
When switch on the power ,network switch 24port has geting hung
I had a DES-1024D 24 port D-Link (DLINK DES1024D) switch that simply didn't power up one day. I decided to open it up and look and I noticed that on the circuit board of the builtin power supply (which was an SB10-033100-10 according to the label, 3.3V 2.5A switch mode power supply) there was a bloated capacitor. We have seen this often on motherboards in the past. Therer were 2 electrolytic capacitors at the very edge of the circuit board closest to the front panel of the switch that were 1000uf 10V. The metal tops of these should be perfectly flat and one was bulging upward. I replaced both of these caps and the switch powered up fine after that.
Aug 11, 2009 | D-Link DES-1024D Express EtherNetwork...
Mixer switch is locked
If this is a 325 watt Artisan, there is no safety switch I know of unless its in the circuit board. Your mixer is broke.
Mar 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Onkyo DV-CP704 will not turn on.
I was recently given a DV-CP704 with similar problems. I fixed my problem, well sort of - read on. I did not have a schematic so I decided to start by checking power supply voltages. I noticed a fluctuating voltage on the K0 pin. This is located on a connector on a circuit board under the disk drawer, and the connector services a cable harness coming from the front panel controls. NOTE: before removing or installing connections, I unplugged the player power cord first then plugged it back in. Not knowing where the voltage was originating from I decided to unplug the front panel connector. The voltage on the K0 pin of this circuit board stabalized at +5 volt and was not fluctuating. I traced out where this pin went to the front panel and among other places it went to the power on/off switch and the drawer open/close switch. I restored the front panel connection and while monitoring the voltage on K0 I noted that when I press either the power on/off button or the drawer open/close button this voltage would go low, not to zero but to some lower voltage but when I released the button the voltage would once again fluctuate. While watching the voltage, if I pressed the power on button when the voltage was near +5 volts, the unit would turn on and off. To me it seemed that this voltage should be stable at +5 volts with no button press and should go low only when there was a button press. Next I decided to unplug the harness that went to the drawer open/close circuit board. The voltage on K0 was still fluctuating so I restored this connection. Then I unplugged the harness that went to the power on/off circuit board. AHHHHH, the voltage on K0 was now steady. I removed this small power switch circuit board. Not much to it, some switches, capacitors, LED etc. I did not see any obvious issues with the circuit board. I decided that either the power switch or the small capacitor across the power switch contacts were breaking down causing the K0 voltage to fluctuate. I decide that the power switch was the easiest to remove so I unsoldered and removed it, plugged the board back in. Now I can power on and off by jumpering where the switch was. The K0 voltage is steady and all other buttons work properly. I assumed that the problem was the power switch. I checked the switch with a high impedance Fluke ohmmeter but to my supprise I did not see any problem with the switch. I decided to reinstall the power switch to recreate the problem however now everything is working normally. I can only assume that the heat I applied to the switch during unsoldering somehow fixed the switch by melting or burning away the problem. In my case it was the power switch however all of the tactile switches appear to be the same type so if there is an inherent problem with these switches, soldering or cleaning I would assume it could have been any one of them. If you want to give this a try, remove the cover, remove the 3 screws that secure the front bezel on the bottom of the player. There are two small clips that need to be lifted to release the front bezel so it can be removed from the player and flipped down to gain access to the back while it is still attached electrically. Attach your voltmeter negative lead to the main chassis (ground) and with the positive lead measure the voltage on the power switch pins. One pin is ground so it should read zero or close to it. The other is the K0 signal and it should be at +5 volts until the button is pressed. I don't know about any of the other buttons but they may also operate in a similar fashion. I hope this may help some of you.
Tom Ulrich
Dec 09, 2007 | Onkyo DV-CP704 DVD Player
JVC AV-32260 32" TV Logo
42 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
