Question about Dell 3100cn Laser Printer
No printing on right side, I replaced the imaging drum but that did not solve the problem.
No printing on right side, fades and dissapears about 1-2 inches Dell 3100cn black prints fades on the right side of the paper. have replaced K, results were the same
  • 3 more comments
  • Anonymous Sep 29, 2008
    Not printing on right side with yellow ONLY; I replaced the toner cartridge and I have tried using the cleaning wand to clean the heads, but none of that solved the problem.
  • KREX Sep 29, 2008
    Not printing on right side with YELLOW only; I replaced the toner cartridge and cleaned heads using the wand. Please notify me when a new solution is offered.
  • Anonymous Apr 17, 2009
    i have the same problem with my dell 3100n. not printing on the right side. i have cleaned all of the contacts and reseated all the toner but still the printer will not print on the right side of the prints. also i have replaced the transfer belt with no luck there, i am waiting on a fuser to try and as a last step i think i am going to replace the HVPS but i will keep you all informed if the fuser of HVPS works. oh and just so there is no confusion to the rest of us corysf62. toner based printers either laser or LED do not have printheads, so cleaning them will do nothing if they are not in the printer in the first place. not bashing you just want people to have the correct information.
  • GuestWho Apr 18, 2009
    Yes indeed, same problem here.  I work for a hospital which purchased 6 of these to deploy.  Every one of them is not printing on the right-hand side of the paper (1-2 inches) as it comes out of the printer.  Even though this is a color printer, 90+% of the printing is done in black only.  Having said that, it doesn't matter what color you print -- the right-hand side is always fading out/no printing.
    Have replaced every toner cartridge, fuser and the image drum with no difference.  The printer (I'm only working on one until I find out what will fix it) has been cleaned out, contacts cleaned, etc.
    Right now these things are pretty much junk.
  • Anonymous Mar 31, 2014
    when printing the left side of print is faded then goes to normal
    Novelist:
  • 188 Answers
There are two possible solutions to this common problem.
1) The Cyan cartridge may not be in 100% of the way. If the handle of the Cyan cartridge prutrudes even slightly, it can obstruct the printhead for the black developer. Remove and reinstall the Cyan cartridge and test.
2) The printhead is dirty, with some toner spillage on the printhead. All new imaging drums also include a new cleaning pad for the cleaning wand.
The cleaning wand is designed to clean toner off of the printhead. you can see this in your printer manual, but basically, just open the front cover, pull the the blue handle on the right side forward ( this opens the access cover for the cleaning wand on the right side of the printer ).
gently pull the cleaning wand out ALL THE WAY, then slide it back in ALL THE WAY. do this several times.
The cleaning wand is intended to travel across the print head in only one direction, which is why you should make sure that it is pulled all the way out.
One of these two solutions should fix your problem. If the problem is resolved, but then reappears after a short time, then you have a defective developer that is leaking toner on the print head. The color of the defective developer can be determined by the color of the cleaning pad after cleaning the printhead as discribed above.
Posted on Sep 28, 2008
  • Cory Friedman
    Cory Friedman Oct 10, 2008
    in response to the Yellow toners not printing on the right side, again, the solution is to remove and reinstall the toner cartridge just behind the color that is not printing. To be specific, it is the locking handle on the right hand side of the toner cartridge ( when looking directly at the cartridges from the front ) just below the one that is not printing on the right border. In this case, with the yellow not printing, when looking at the yellow cartridge, the one just below it is the black toner.
    Remove and reinstall the black toner cartridge, making sure that the locking handle is 100% in the locked position.
    Last but not least, I have seen where replacement, non-Dell toners where used and not in spec so that the handle was not fitted correctly and therefore the cause of the problem. If reseating the toner does not work, try replacing it and test again.
My HP3505 we just installed a ne black toner, now when we print it leaves a small line about 3 inches in from right side of paper every 1 inch. all the way down. Is this becasue or drum is dirty
hi
if you have not replaced the image drum (fuser) after three or four toner replacement changes, you will need to replace the fuser assembly to avoid unwanted lines and grainy or faded prints.
it is also a good idea to replace the rollers as well, if they have not been replaced either
RM1-2763-020CN fuser assembly worth about $200 with exchange of your old fuser
RM1-2727-000CN, worth about $10-$15
please send me 4 thumbs up
Aug 15, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Only prints on one side of paper. print starts to fade to nothing from right to left
Print the "supplies status" page.
Replace any cartridges that are low, Replace the imaging drum if it is low or empty.
Mar 22, 2011 | HP LaserJet 2550L Printer
OUR CM1017 MFP IS HAVING AN ISSUE WITH TONER ON THE PRINTED PAGE: THE LEFT AND RIGHT MARGINS, MAYBE 1 INCH INTO EITHER SIDE IS PRINTING BUT IN A FADED SHADE OF WHAT THE REST IS. CARTRIDGES ARE FINE BUT...
sounds like a imaging drum is getting old. they have a finite lifespan. Especially if the machine is used frequently. Look for an imaging drum replacement. Cheers.
Aug 25, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
I have two lines about a 1/8in on each side of the paper that are smudged or faded on a HP Laserjet 2600n Printer how can I solve this??
Usually that means you need to replace either the image drum or some of the smaller parts to fix this. If it seems to fade out more as you print more pages but comes back the next day when its cold then you may need to price out a drum or corona wire. The fix is just replacing the part which is about the same as replacing an toner drum BUT you need to make sure the parts cost isn't more than the printer is worth.
Oct 22, 2009 | HP Color LaserJet 2600n Printer
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
u hav to check the drum and adjust its position,u also check the position of the tray in the printer.
Aug 20, 2008 | Dell 3100cn Laser Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
Dell 3100cn Laser Printer Logo
438 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
